ESP then check engine then hobbled running?
2014 VOLKSWAGEN PASSAT
113,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
CLHENDON
Vehicle ran great, except a little occasional hesitation upon acceleration from stop. Clock spring replaced at VW dealer, then 30 short miles later ESP light, then check engine light, then hobbled idle. Took it to another VW dealer, who wouldn’t consider the clock spring association, replaced all fouled spark plugs, cleared the codes and we ran for 200 miles with no issues. Then, after a long idle, the exact same thing (ESP/check engine/ hobbled idle) happened. Now the original VW dealer service shop says its bad fuel injectors, bad coils and bad spark plugs (after only 200 miles!)
Any advice? I know the clock spring isn’t the first place to look but the car runs great except for these two episodes.
Mar 14, 2023 at 5:46 PM
It sounds like you may have a MAF sensor that is out, but we need to run the codes to see what is going on. This guide can help us:
Please go over this guide and report back.
Mar 15, 2023 at 12:28 PM
