I'm looking for the firing order for my car listed above ltz.
Sep 15, 2019 at 11:05 AM
CERTIFIED EXPERT
Good afternoon,
I attached the firing order for you. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to enlarge)
Sep 15, 2019 at 12:30 PM
JOEY69
MEMBER
1 POST
Need to know the firing order.
Sep 19, 2020 at 1:40 PM
(Merged)
HARRY P
CERTIFIED EXPERT
Here it is.
(Merged)
WRENCHTECH
CERTIFIED EXPERT
I believe this is what you are probably looking for.
(Merged)
BLAKE1985
MEMBER
1 POST
what is the firing order for a 6 cylinder 3.1 engine
(Merged)
2CARPRO JACK
CERTIFIED EXPERT
here ya go
(Merged)
MICROPHONE DOCTOR
MEMBER
1 POST
Six cylinder automatic 120,000 mile.s
What is the firing order for the spark plugs? when changing the spark plugs I think the firing order got mixed up.
(Merged)
BLUELIGHTNIN6
CERTIFIED EXPERT
Firing order for the 3.1 liter is below.
3.1 liter engine:
Firing order: 1-2-3-4-5-6.
Distributor-less ignition system.
Thanks for using 2CarPros.com!
(Merged)
ALDEAN49
MEMBER
1 POST
Engine Performance problem
2000 Chevy Malibu 4 cyl Front Wheel Drive Automatic
What is the firing order for a 2000 Malibu 3.1?
(Merged)
LSAUTO
CERTIFIED EXPERT
the firing order is Firing order: 1-2-3-4-5-6. and the coils should have the cyl marked hope this helps lsauto
(Merged)
SODAJOE
MEMBER
1999 Chevy Malibu
what is the firing order and cyclinder placement for a 3.1 v6
(Merged)
RHALL77
CERTIFIED EXPERT
cylinders 2, 4, 6 are at the front of the car 2 being at the front of the engine. 1, 3,5 are at the firewall side of the engine and 1 is starting at the front of the engine
(Merged)
RND
MEMBER
1 POST
I need a diagram for firing order for coil pack and spark plugs
(Merged)
CERTIFIED EXPERT
Here is the cylinder order as well (below) Please let us know if you need anything else to get the problem fixed.
Firing Order .................... 1-2-3-4-5-6
(Merged)
JUSTIN_19
MEMBER
1 POST
i need a diagram on a v6 3.1 engine on a 1997 chevy malibu LS. Its that i dont know the sequence and i know im supposed to mark them but i thought i knew where they went but i sort forgot where they went so if i can know the order of it or show me a diagram
(Merged)
RHALL77
CERTIFIED EXPERT
1,3, 5 are on the firewall side of the engine. #1 ia up front. 2,4,and 6 are on the radiator side. #2 is at the front of the engine. your module should be labeled all ready.
(Merged)
KENDRICK DENSON
MEMBER
1 POST
1997 Chevy Malibu 6 cyl Two Wheel Drive Automatic
Put in new spark plugs and new wires but dont remember what order the wires go
Sep 28, 2020 at 10:27 AM
(Merged)
SERVICE WRITER
CERTIFIED EXPERT
