Flex plate torque specs needed?
2016 FORD F-150
190,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
What's the torque spec for the flex plate to crankshaft bolts?
Mar 11, 2025 at 5:40 AM
Sure, this bolt is torqued to yield and are not re-usable. Flex plate torque specs.
Install the flexplace and the bolts.
Torque:
Stage 1: 20 Nm
Stage 2: 60°
Here is the tightening sequence. Check out the images (below). Let us know if you need anything else.
Mar 11, 2025 at 1:58 PM
Thank you very much.
Mar 11, 2025 at 6:27 PM
You are welcome, please use 2CarPros anytime we are here to help.
Mar 12, 2025 at 10:20 AM
