bronco ii hesitation/stalling PLEASE HELP
FORD BRONCO
BRONCOIIBLUES
Hello, I have a 1988 ford bronco ii, 4wd, automatic, 2.9 v6, 30,000 miles on rebuilt engine. Bronco starts fine, runs good have intermittent hesitation/stalling and the check engine light will flash when this happens. I have replaced the distributor cap, rotor button, plug wires, spark plugs, ignition module, ignition coil, fuel pump relay and both fuel filters. I get two engine codes: 95-Fuel pump relay secondary circuit failure and 48 Loss of IDM. I can hear fuel pump come on and checked fuel pressure, it is 40 psi. Any help will be GREATLY appreciated. Thanks
Apr 15, 2007 at 12:15 PM
BRONCOIIBLUES
[quote:6a996ec10e="broncoiiblues"]Hello, I have a 1988 ford bronco ii, 4wd, automatic, 2.9 v6, 30,000 miles on rebuilt engine. Bronco starts fine, runs good have intermittent hesitation/stalling and the check engine light will flash when this happens. I have replaced the distributor cap, rotor button, plug wires, spark plugs, ignition module, ignition coil, fuel pump relay and both fuel filters. I get two engine codes: 95-Fuel pump relay secondary circuit failure and 48 Loss of IDM. I can hear fuel pump come on and checked fuel pressure, it is 40 psi. Any help will be GREATLY appreciated. Thanks[/quote:6a996ec10e] Could it be the ignition stator??
Apr 16, 2007 at 1:25 PM
THADANGERRANGER
Try the MAP sensor!!! That could be your problem!!!
May 1, 2007 at 9:42 AM
TDUB
I also have a 1988 bronco 2 as well 2.9 li 4wd automatic i have 86,000 miles and my bronco is doing the exact same thing. did you ever find out what the problem was? Im going to get a map sensor for it tomorrow. I feel you man about your bronco. let me know what was up i would greatly appreciate it
Feb 2, 2011 at 7:59 AM
BRONCOIIBLUES
Tdub- yes, I found my problem. The problem was the computer. The computer sends 12 volts to the eec relay. The 12 volts from the computer would drop out for a second and then come back. The eec relay powers the fuel pump relay (among other things...igntion...) So when the computer would drop the 12 volts to the eec relay I would lose power to the fuel pump and ignition system as well.
I figured this out by driving with a small bulb in parallel to the eec relay 12 volt power from the computer. Every time the bronco would hesitate, the bulb would flicker- telling me I was losing power to the bulb and relay. Instead of replacing the computer, I cut the wire to the eec relay and spliced it with a switched 12 volts.
Hope this helps.
Feb 2, 2011 at 9:20 PM
