1994 Ford Escort White smoke
1994 FORD ESCORT
120,000 MILES • 4 CYL • FWD • MANUAL
ELLI
When I first start the car in the morning I get a large amount of steamy white smoke comming from the exaust pipe. It goes away in a couple of minutes And the car runs fine, the car does not run hot, and the coolant level is good. This is relatively new problem, This car has been a great runner and gets me around 35 mpg. I've checked and all four plug wires are firmly on the sparkplugs.
Oct 18, 2010 at 8:04 AM
WRENCHTECH
  • 20,761 POSTS
The smoke means your burning something. White usually means coolant being burned but a little gray tinge to it can mean oil. If your not losing any coolant, then it's probably bad valve seals.
Oct 18, 2010 at 9:48 AM
