remove the old fittings at the nearest connector where you can remove them with a FLARE NUT WRENCh.
next step is bend the new one to the right shape then reattach, bleed lines, abs and your good to go
a tip, press brake pedal down a little over half way to prevent loosing fluid.
Sep 27, 2008 at 10:12 AM
