2003 Ford Expedition 2003 EXPEDITION BRAKE PEDAL GOES TO FL
2003 FORD EXPEDITION
104,000 MILES • V8 • 4WD • AUTOMATIC
SVARWIG
When I have driven for a while and quickly put on the brakes to abruptly stop, sometimes the pedal will go all the way to the floor and stop at the floor. The vehicle does stop. If I let off the pedal and push it again, it doesn't go as far down. The vehicle has always stopped.
Oct 4, 2010 at 8:56 AM
This could be a few things. First check to make sure the brake fluid is full. Next, have someone push on the brakes while you check the rubber brake hoses at each wheel. Make sure none are expanding. Also, check for leaks at all lines, calipers, wheel cylenders, master cylender. If everything is good, it sounds like there is a problem with the master cylender.
Let me know what you find.
Oct 4, 2010 at 10:33 AM
