NEED TO KNOW HOW TO RESET LOW OIL PRESSURE LIGHT AFTER TRUCK HAS BEEN SERVICED
Dec 31, 2009 at 1:44 PM
CERTIFIED EXPERT
There is no reset for a low oil pressure light. Is the engine making any ticking or knocking?
Jan 2, 2010 at 11:53 PM
ALEXWASSERMAN
MEMBER
1 POST
Joe,
I get that same warning, but only when the engine is off, but electrics are on. Never when the engine is on. So, when I first turn the keys in the ignition and leave it for a minute I'll get it, but after starting it clears and never shows.
Is that normal?
Thanks.
Alex
Nov 9, 2010 at 8:34 AM
CERTIFIED EXPERT
That is normal. When the engine is off, it isn't producing oil pressure. Once it starts, it does and the light goes out.
Nov 9, 2010 at 10:51 AM
SARAH DAVIS
MEMBER
1 POST
Long shot, I have the same problem as above. When keys are turned to auxiliary before crank the low oil light comes on. I replaced the oil pressure sensor, and still have the light before cranking but not while running. What else could be causing the light?
Feb 25, 2019 at 10:54 AM
CERTIFIED EXPERT
The light is supposed to come on when the engine is not running, If the light does not come on when it is running check the oil level and you should be okay. Use 2CarPros anytime, we are here to help. Please tell a friend.
