1976 Ford F150 LPG to gas
1976 FORD F-150
REVANX
Engine Mechanical problem
1976 Ford F150 6 cyl Two Wheel Drive Manual
i need someone to explain to me how to change a truck that was converted to LPG (liquid propane gas ) back to gas and i need to know what all parts i will need to do it
Mar 2, 2010 at 10:49 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Was this converted to LPG only or was it duel fuel?
Mark. (mhpautos)
Mar 2, 2010 at 10:54 PM
REVANX
just LPG
Mar 2, 2010 at 10:59 PM
MHPAUTOS
  • 31,937 POSTS
If the fuel tank was removed, that is obvious, and if still there get it cleaned, check all fuel hoses, fuel pump, have the carby re built as it will be full of corrosion, remove all the LPG fittings, replace any existing fuel lines, replace cut & by passed heater hoses that were used for the converter pre heating, with out seeing i don't know what has been done with the electrics, mainly the fuel tank sender unit, remove any excess in wiring used for gas only, start here.
Mark (mhpautos)
Mar 2, 2010 at 11:06 PM
REVANX
thank you
Mar 2, 2010 at 11:10 PM
MHPAUTOS
  • 31,937 POSTS
If you have any further questions, feel free to re post, thank you for using 2carpros, your feed back is always welcome.
Mark (mhpautos)
Mar 2, 2010 at 11:15 PM
