1993 Ford F150 Grabbing / Loud Noise
1993 FORD F-150
130,000 MILES • V8 • 2WD • AUTOMATIC
MBFREE66
When I put on brakes they grab and make a loud grinding/squealing noise on the front. I have changed the pads and the rotors look ok. Any suggestions?
Dec 10, 2008 at 9:11 PM
Hi:
the only thing that would make the noise you described are the brakes or a rusted / bent backing plate. Make sure it isn't being hit by the caliper and being moved into the rotor.
Let me know what you find. (Also, make sure the calipers are tight and not rubbing against the wheel itself. You will se evidence of that on the wheel itself.
Mar 10, 2021 at 12:02 PM
