ABS light is on and there is no reason why?
2000 FORD F-150
134,000 MILES • V8 • 4WD • AUTOMATIC
FRANKRED
The light is on and there is no reason why. Also the cruise dosn't work. Checked all fuses, and they're all good. Before I go spend thirty bucks I thought I would see what you all had to say.
Thanks for the help
Dec 13, 2007 at 2:00 PM
MERLIN2021
  • 17,250 POSTS
Try unplugging the deactivation switch for the cruise, it's The brake pressure switch, on or just under the master cylinder, I don't know if yours was recalled but a lot of them were, possible fire hazard...Not too expensive, if you replace it pour some brake fluid into the new one before you mount it.
Dec 13, 2007 at 3:39 PM
If the ABS light is on we need to know the codes which could have something to do with the brake lights like the switch that MERLIN2021 said. Here is a guide to help get the codes so we can see what's going on.
https://www.2carpros.com/articles/anti-lock-system-testing-and-repair-abs
Sep 19, 2024 at 3:00 PM
