Low brake pedal spongy I did not turn the rotors or drums
1995 FORD F-350
11,300 MILES • V8 • 2WD • AUTOMATIC
KARL R.
I've replaced the master,shoes, & pads.I did not turn the rotors or drums , but did deglaze them. I've bled (3 times ) and the rears are adjusted. I still have a soft and low pedal . I'm sure it's something I did because I have the same problem on a Chevy that I've replaced the same items on. Can you help so I don't repeat the same mistake ?
Feb 17, 2009 at 10:24 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
often there is air trapped in the lines and you may have to use a pressure bleeder to clear this air out, also try bleeding the master first, then using brake hose clamps lock off all brake hoses and test the pedal, if hard and high, problem will be in the lines past the clamps, start here.
Mark (mhpautos)
Mar 17, 2021 at 12:25 PM
BRONCOEARL
  • 6 POSTS
I had a similar issue. I got air in the abs system. sounds like you did too. there is a specific bleeding technique on vehicles with abs. The instructions should be in the manuals, i called the dealer and found the info in a chilton manual. broncoearl
