1999 Ford Mustang transmission Filler tube
1999 FORD MUSTANG
12,300 MILES • 6 CYL • 2WD • AUTOMATIC
JEFF CARPENTER
How do I replace the o-ring for the transmission filler tube? Were can I purchase the correct size 0-ring?
Oct 2, 2010 at 4:56 PM
FACTORYJACK
  • 4,159 POSTS
Fill tube R&R shows to remove the top RH bellhousing bolt(the bolt that secures the tube), and lift upward on the tube. I don't show an illustration of an o-ring, or seal. I would imagine that a dealer parts source would have(or could get) it. Otherwise, if it is an o-ring type seal, you may be able to match it up with one from a standard or metric o-ring kit. Lubricate it with some ATF, or petroleum jelly(vaseline) prior to installation.
Oct 3, 2010 at 12:04 AM
