2002 Ford Mustang oil change
2002 FORD MUSTANG
56,000 MILES • 6 CYL • 2WD • AUTOMATIC
ANZAKID
I have been haveing my motor and auto transmission
oil changed at a quick change place. I noticed that they do not remove the driain plug from either location. After some thought on the subject I don't think I will return. Am I wrong?
Jan 22, 2009 at 7:53 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:baa3ea555b="anzakid"]Warranty problem
2002 Ford Mustang 6 cyl Two Wheel Drive Automatic 56000 miles
oil changed at a quick change place. I noticed that they do not remove the driain plug from either location. After some thought on the subject I don't think I will return. Am I wrong?[/quote:baa3ea555b]
To begin with how often are you having your Tranny Fluid changed. It is probably not recommended for another 35k or so miles. And most Transmissions do not have a Drain Plug. You remove the Tranny Pan to drain.
Now, the Oil - If you feel that the oil isn't being change all you have to do is pull the dip stick and the oil should be a clear carmel. Unless you have driven it for a few days or more, then it should be kinda see through gray.
If you would like to change your own oil and filter check out the link below.....
https://www.2carpros.com/how_to/how_to_change_oil_filter.htm
Jan 22, 2009 at 8:04 PM
