1990 Ford Ranger rear end lock up
1990 FORD RANGER
BOOSBABY26
Drive Train Axles Bearings problem
1990 Ford Ranger Two Wheel Drive Manual
when truck is put into reverse the rear end or back brakes lock up but then shift to 1st gear and it doesnt. what would cause this issue
May 2, 2010 at 5:53 AM
What I need you to do is securly and safely lift the rear wheels off the ground. Place the vehicle in neutral and see if you can turn each tire in reverse.
Let me know what you find.
May 11, 2010 at 1:32 PM
