1992 Ford Ranger crankshaft posionning sensor
1992 FORD RANGER
102,369 MILES • 6 CYL • 2WD • AUTOMATIC
TGBREM
does this vehicle have a crankshaft posioning sensor
Nov 8, 2008 at 6:48 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes. It should be under the crankshaft pully. You need to remove the harmonic balancer and then you will see it. It has three little blocks on it. It should be on the RH side of the front of the block.
Nov 8, 2008 at 7:04 PM
A 2.3L has it-on the 2.9/3.0/4.0 6 cylinders-the 4.0 comes with it-CPS
