Transmission problem
1998 Ford Ranger 6 cyl Four Wheel Drive Automatic
I recently replaced my engine. We pulled the engine and transmission out together as it was easier then dropping the transmission from underneath the truck. We replaced the fluid and filter. We put everything back together and the engine fired right up but when I shifted it into gear it didn't go anywhere and the rpm's stayed the same. To determine if the transmission fluid pump was pumping we disconnected one of the lines into the radiator expecting to see fluid squirt out when the engine was running. It did not. I've heard that there might be a special way to prime the pump. Is that true? How do I fix this?
Feb 23, 2010 at 8:08 PM
