Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Image (Click to enlarge)
Jul 16, 2020 at 12:32 PM
KOLTERMAN_THOMAS
MEMBER
1 POST
how do i get to the back sprark plugs #s 1 2 3 and what would be the easy way
May 23, 2021 at 11:37 AM
(Merged)
BMRFIXIT
CERTIFIED EXPERT
You don't have to remove the manifold you can get a few ratchet extensions with a little play in them taped together with spark plug socket and remove them
(Merged)
JOE THERIOT
MEMBER
1 POST
my engine is beginning to run badly as the car warms up and gets worse as the day gets hotter. it sounds like its running out of fuel. i am wondering where, if there is one, the crank sensor is, and the throttle position sensors are. i need to change the spark plugs and wires?
May 23, 2021 at 11:38 AM
(Merged)
CERTIFIED EXPERT
Here is a guide to help change the spark plugs
https://www.2carpros.com/articles/how-to-change-spark-plugs
Crankshaft Position Sensor
2003 Ford Taurus V6-3.0L DOHC VIN S
2003 Ford Taurus V6-3.0L VIN 2 Flex Fuel
Throttle Position Sensor
(Merged)
SEBUMSEBACEOUS
MEMBER
How do I access the rear spark plugs on a 2002 Taurus; 6-cyl.?
May 23, 2021 at 11:39 AM
(Merged)
BLACKOP555
CERTIFIED EXPERT
you may have to lossen up the motor mounts and tilt the engine forward to reach them.
(Merged)
TRACY1964
MEMBER
how's the easiest way to change the 3 back spark plugs
(Merged)
TORNADO
MEMBER
1 POST
I did replace the spark plugs on my Taurus 02 without a problem. I did it with a 5/8 " extension and a normal Craftsman 8" wrench The one in the middle (back in the middle) is the one that takes a little more time. I recommend you to use original Motorcraft ones. I wanted to use another brand and it didn't work well.
(Merged)
ANDRES1234
MEMBER
how do i change the rear spark plugs located at rear of engine at the fire wall.
May 23, 2021 at 11:40 AM
(Merged)
BMRFIXIT
CERTIFIED EXPERT
Its depend on you engine size
I am going to assume you have the one that need upper intake removed
or moved aside
OR
(Merged)
LITTLEDONNA
MEMBER
1 POST
How do I get to the 3 rear spark plugs on my 2001 Ford Taurus 24V-DOHC? They are the 1,2,3 pistons. What is the best way to change those plugs?
(Merged)
BLACKOP555
CERTIFIED EXPERT
some claim to be able to remove the windshield wipers and the wiper cowl. and maneuver to it. but when i do it i always remove the upper intake manifold and reach back behind it and do it from there. Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
(Merged)
CHRIS R INGLES
MEMBER
1 POST
I am replacing the spark plug in my 2000Taurus, 3.0 vulcan motor. I have replaced the front 3 but how do you get to the back 3?
May 23, 2021 at 11:41 AM
(Merged)
BMRFIXIT
CERTIFIED EXPERT
Remove Upper intake manifold removed for clarity. Remove the ignition coil-on-plug. Disconnect the electrical connector. Remove the bolt. Remove the coil and plug.
(Merged)
COCO08
MEMBER
1 POST
The diagnostic reading showed that I had three spark plugs that were misfiring. The mechanic says that it will take two hours to replace spark plugs because the back three are located behind the manifold. My boyfriend says that he can replace them but I was leary about letting him take the manifold apart. Is this a simple process?
(Merged)
FLEXY5
CERTIFIED EXPERT
You shouldn't need to remove the intake to do this, unless it is the taurus SHO. The 3.0 vulcan engine has enough space to reach back from the sides. You can't see them, but you can feel them. This is why it takes so long to do. It's just time consuming and sometimes frustrating. The most he would have to remove is the air intake tube. Two can be reached from the driver's side, the other from the trans side. Good luck, let us know if you need more help.
(Merged)
2CP-ARCHIVES
MEMBER
I was told about a month ago that i need to get my spark plugs and spark plug wires changed. Problem was they wanted to charge me Almost $20.00 per spark plug and another $80.00 for the wires. And on top of that $200.00 in labor. I went and got the parts online but haven't had a chance to take my car in to get the stuff changed. can you help me?
(Merged)
CERTIFIED EXPERT
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car:
(Merged)
COUPLE4CHRIST
MEMBER
1 POST
i am replacing the spark plugs and wires on my 99 taurus and i need to know how to get to the back three spark plugs. Any suggestions??
Thanks
Ben
May 23, 2021 at 11:42 AM
(Merged)
ZACKMAN
CERTIFIED EXPERT
This guide can help help diagrams below to help you on your car.
(Merged)
ANDRES1234
MEMBER
How do i change the spark plugs at the back of engine at the fire wall. als o where is the gas filter located.
(Merged)
BMRFIXIT
CERTIFIED EXPERT
what do u have for engine (DOHC SOHC )
1.Open hood and remove both windshield wiper pivot arms.
Remove 8 plastic retainers from cowl vent screens to inner panels by turning 1/4 turn counterclockwise.
Remove 5 clips retaining cowl vent screens to inner panels.
Remove left and right side cowl vent screens from vehicle.
Remove 4 bolts retaining ignition coil 4 and position out of the way.
2.Disconnect negative battery cable.
Ensure left and right side cowl vent screens are removed.
Disconnect electrical connector from ignition coil and remove 4 ignition coil hold-down screws.
Remove ignition coil to access spark plugs on cylinders No. 1, 2 and 3.
Disconnect electrical connector from Intake Manifold Runner Control (IMRC) actuator.
Remove IMRC mounting screws, and lay IMRC actuator aside to access spark plugs on cylinders No. 4, 5 and 6.
NOTE: Spark plugs must be marked so they may be installed into the same cylinder from which they were removed.
3.Disconnect ignition wires from all spark plugs.
Loosen spark plugs and use compressed air to remove any dirt or foreign material from spark plug areas of valve covers.
Remove spark plugs.
(Merged)
TAMI LYNN
MEMBER
1 POST
I need a video on how to change the spark plugs and wires on 1997 Ford Taurus station wagon Gl.
May 23, 2021 at 11:43 AM
(Merged)
CERTIFIED EXPERT
Hi Tami,
Here are a couple videos. I assume you are asking because you may have to remove the intake to do the rear? There are tricks but sometimes it is easier to just remove it.
My car is a 1996 Ford Taurus LX, I was driving in a passing lane and all of a sudden my rpm went up to 4000 and then there was a bad smell. I pulled over and there was little smoke but not bad. When I looked at the exhaust it was coming out in puff clouds and was actually making a putting noise. I had my husband change the spark plugs and he found one that was not firing and we changed that plug. Now it runs worse than before. My husband thinks that there is a piston that has no fire going to it. Now what?
(Merged)
JGAROFALO
CERTIFIED EXPERT
Start with the basics. Verify with a spark tester that the spark plug is not getting spark. Since your ignition system fires the cylinders in pairs, if one fires and the other does not, there is a possibility of a shorted coil pack.
This guide will help you change the spark plugs correctly.
Also a compression test would be in order. Bad compression will also cause a cylinder not to fire.
Smoke from the tailpipe can also indicate a problem with a head gasket or intake manifold gasket.
