1999 Ford Windstar rough idle and heat up
1999 FORD WINDSTAR
DGOLDENBERG1213
  • 17 POSTS
Engine problem
6 cyl Front Wheel Drive Automatic 116000 miles
engine ok most of the time, but, after engine reaches max temp; say and hour or so on the freeway. When I come to a full stop at a light or stop sign or heavy traffic, engine will start to idle rough and temp; gauge begins to climb close to if not to the hot point. if I take out of gear into neutral engine smooths out and temp drops.
or if i start to move forward again it will smooth out and return to normal temp. cooling system has been power flushed and coolant changed. no leaks of any kind. freshly tuned, new fuel, air oil filters.
no warning lights on. what's up??!.
Dec 14, 2007 at 4:49 PM
MERLIN2021
  • 17,250 POSTS
When the car is warmed up, check for the cooling fan, see if it comes on! Try turning a/c on the fan should start right away...You may need either a fuse, relay in the power distibution center, or a new fan...Also check the coolant temp sensor, if it's not telling the PCM to turn on the fan, it won't!
Dec 14, 2007 at 5:05 PM
