Possibly fried the computer after putting my multi-meter to the plug and ground to the engine block
2013 CHEVROLET EQUINOX
135,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
GLEVI1127
  • 7 POSTS
I had a slight misfire sometimes while idling so I decided to check the plugs and the PCV valve since I read on some forums that the PCV hose was known for getting plugged. Once I was done with the plugs and put the coils back on I could hear a clicking noise coming from one of the coils randomly every couple minutes. Me being the genius that I am decided to put my multi-meter to the plug and ground to the engine block and I believe I may have shorted out the computer. I have an obd2 3100i scanner and it now shows most of the car's components are in the red when they were all green before and the car runs way worse. I didn’t even take it out of the garage. Do I need a new PCM? I messed up and now I need help please!!
Feb 17, 2020 at 2:10 PM
JOETECHPRO
  • 705 POSTS
Hey GLEVI1127,
The first step will be to check all of the fuses in the under hood and interior fuse box.
There is a guide in the link below to check and replace fuses:
Start with this and let us know what you find.
It is amazing how many electrical faults can be traced back to a blown fuse.
Best of luck.
Regards, Joe
Feb 17, 2020 at 2:17 PM
GLEVI1127
  • 7 POSTS
Okay, I’ll see what I can find and get back to you. thank you
Feb 17, 2020 at 2:19 PM
GLEVI1127
  • 7 POSTS
I seem to be getting all kinds of odd readings. Dash lights on but no keys in the ignition I got .09 on the ECM 02 sensors and ignition fuses. I also heard what I think were the ignition coils clicking randomly. Then with the keys in I got point 06 or 07 volts coming through those five fuses. I’ve double and triple checked my ground and the battery on my multi-meter. I think I have a short some where don’t I?
Feb 17, 2020 at 3:04 PM
GLEVI1127
  • 7 POSTS
Also my battery shows 11.6 volts and the car hardly started like the battery was nearly dead. And the emission light that went red when this all happened are. Fue, egr, cat, 02s, htr and Eva. They were all green before I did whatever I did.
Feb 17, 2020 at 3:06 PM
GLEVI1127
  • 7 POSTS
So I think I’ve found the problem I’m just not sure I’m going to do from here. It seems that the slot for the engine control relay has a full twelve volts on two of the pins and five volts on the third and .06 on the four. I am fairly certain there should only be one pin with twelve volts going to it. Correct me if I’m wrong and any advice moving forward would be much appreciated.
Feb 17, 2020 at 4:47 PM
The battery voltage is low. lets confirm the battery failure using this guide. Here are the fuse locations as well so you can double check them:
Feb 17, 2020 at 7:04 PM
GLEVI1127
  • 7 POSTS
I used my scanner to test the alternator and battery just before all these problems started happening. I found that the relay for the engine control is getting power across three of the four pins so I’m looking into removing the fuse box to see what I find. I’m just a little Leary about doing this since I read that disconnecting the battery could leave me with even more problems then I already have. Any advice or tips would be greatly appreciated.
Feb 17, 2020 at 7:24 PM
JOETECHPRO
  • 705 POSTS
Hey GLEVI1127,
Can you please confirm you have checked the fuses first.
There is a lot of time wasted in electrical diagnosis by people not beginning with confirming that the fuses are good.
Please let us know.
You should have 12V at either side of the ECM fuse in the under hood fuse box with the ignition on.
This will confirm that the ignition relay you are testing is operating correctly.
It is fuse 42, 20amp.
Regards, Joe
Feb 17, 2020 at 9:30 PM
GLEVI1127
  • 7 POSTS
There is .09 volts on the fuse with the key off and I need to go purchase a battery charger or cables but there’s 11.74 with the key on. Should it not read 0 volts with the key off though? I’m going to check for a short in one of the injectors this morning once I track down some cables or a charger. Any further advice is always helpful thank you.
Feb 18, 2020 at 9:16 AM
JOETECHPRO
  • 705 POSTS
Hey GLEVI1127,
I wouldn't worry about the 0.09V that is completely normal.
If you have 12V at both sides of that fuse with the ignition on then the relay is functioning correctly.
Can you please charge the battery and delete the fault codes?
Run the engine and recheck that codes that you have stored.
Please give us a list of the codes you have present.
Regards, Joe
Feb 18, 2020 at 8:21 PM
This guide will help:
Feb 22, 2020 at 10:42 AM
