lean fuel in bank 1 put a new PCV valve on?
1999 FORD F-150
172,000 MILES • 4.2L • V6 • 2WD • AUTOMATIC
CAM61
  • 5 POSTS
The truck listed above is an XLT. Engine light came on obd code lean fuel in bank 1 put a new PCV valve on. The truck started acting rough when idling and cutoff, it would backfire and act like it wasn't getting any fuel. I have put a new fuel filter, air filter, MAF sensor and alternator (battery light wouldn't go off on dash battery wouldn't hold a charge. Battery is fine per AutoZone. Still having the same issues. Fuses and relays checked also. Any help would be appreciated. CAM
Jun 13, 2023 at 7:39 PM
It sounds like you have a weak fuel pump, here is how to check the fuel pressure so we can confirm the issue. The battery light problem you need to start a new question for because we only handle one problem per thread. Here is a guide to help you check the pressure and you can rent a fuel gauge for free or cheap from the local auto parts store.
Engine Running .................... 193-310 kPa (28-45 psi)
Key ON Engine OFF .................... 240-310 kPa (35-45 psi)
This guide may help as well
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Jun 14, 2023 at 11:32 AM
CAM61
  • 5 POSTS
I checked the fuel pressure engine running it was 30psi. Key on Eng off I got no pressure. It sounds like the fuel pump needs to be replaced.
Jun 16, 2023 at 7:12 PM
Jun 17, 2023 at 9:47 AM
CAM61
  • 5 POSTS
Should I replace the fuel pump or fuel pump assembly?
Jun 17, 2023 at 11:57 PM
I would replace the assembly with a high-quality part.
Check this one out on Amazon:
https://amzn.to/3NzvDQ2
Please let us know how it goes.
Jun 19, 2023 at 11:07 AM
CAM61
  • 5 POSTS
I replaced the fuel pump assembly like you said and you were right. The truck is running great. Thanks so much.
Jun 23, 2023 at 4:24 AM
Thanks for letting us know, we are here to help, please use 2CarPros anytime. Can you please leave us a rating? (copy entire link)
https://www.google.com/search?q=2carpros&gs_ivs=1#lrd=0x80dcd47364be5d0d:0xba091aa4209f4497,1,,,&tts=0
and
https://www.sitejabber.com/reviews/2carpros.com
Thank you
Jun 23, 2023 at 10:41 AM
