Fuel code keeps coming back after i turn the car off and on?
2014 BMW X5
157,009 MILES • 6 CYL • TURBO • 2WD • AUTOMATIC
BHAMDOC1973
  • 2,008 POSTS
If i delete the codes i get the 2 in the picture. Some readings for engine off and then on.
Jan 1, 2025 at 10:02 AM
The 165011 and 165013 diagnostic trouble codes (DTCs) for a 2014 BMW X5 typically refer to issues related to the crankshaft position sensor and valvetronic system. How does the engine seem to run, can you unload a video? Here is the location of the crankshaft sensor which I would replace and then clear the codes. Check out the images (below). Let us know what you find.
Jan 2, 2025 at 10:39 AM
BHAMDOC1973
  • 2,008 POSTS
Engine runs smoothly with no issues. The instructions are for the diesel motor. I have gas inline 6-cylinder N55 motor. No leaks or other issues.
Jan 2, 2025 at 10:43 AM
My bad, sorry, here you go. Check out the images (below).
Jan 3, 2025 at 11:33 AM
