Fuel Gauge not working?
2010 TOYOTA COROLLA
210,000 MILES • 4 CYL • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 754 POSTS
The vehicle fuel gauge is not functioning, and the fuel level indicator light is on but there is fuel in the fuel Tank, when the ignition is on or when the Engine is running, the Gauge needle will move a bit.
I checked for power at the connectors of the fuel pump Gauge, there is 2v. Could I get a wire diagram for the fuel Gauge and fuel pump?
Aug 9, 2023 at 9:37 PM
It sounds like the fuel level sensor has gone bad which is common, here are the wiring diagrams for the gauge so you can see which wires to test and how the system works. I also have included how to change the unit out in the images below. Check out the images (below). Please let us know how it goes.
Aug 10, 2023 at 5:38 PM
BLESSING EWOBOR
  • 754 POSTS
Thank you very much.
Aug 11, 2023 at 3:58 AM
You are welcome. Please use 2CarPros anytime, we are here to help.
Aug 11, 2023 at 10:17 AM
BLESSING EWOBOR
  • 754 POSTS
Hello, after a while the vehicle was taking longer time to crank, it was behaving as having a bad battery, I reconnected the battery terminals. And when the engine started the Guage was now working fine.
To my surprise the fuel gauge terminal reads 10v but it was unable to power a test light before the battery was reconnected.
Aug 14, 2023 at 10:01 AM
