The fuel pressure regulator is part of the fuel pump assembly. To replace this, you need to replace the fuel pump assembly. There is a plate under the rear seat that will give you access to the pump assembly. It is an easy replacement. I attached a picture of the pump. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Below you will find the location and process from the manual on how to check this as well.
Please let us know if you have other questions. Thanks
May 25, 2021 at 1:27 PM
(Merged)
WRENCHTECH
CERTIFIED EXPERT
The pressure regulator for that vehicle is built into the fuel pump assembly, inside the fuel tank.
(Merged)
RMORGAN94534
MEMBER
1 POST
The idle is if if at all. When you give it gas it stalls
(Merged)
CARADIODOC
CERTIFIED EXPERT
Fuel pressure gauge. If the regulator is on the engine and has a vacuum hose going to it, pressure should go up when that hose is disconnected. Pressure regulators cause a lot of trouble on General Motors cars and trucks, not on other brands.
