Fuel pump wiring?
2003 CHEVROLET SILVERADO
190,000 MILES • 4.8L • V8 • 4WD
MARK BLANEY
If you disconnect the fuel pump while battery is hooked up will you have to retrieve the check engine code and clear it to restart engine? I need the fuel pump wiring
Aug 29, 2016 at 3:22 PM
HMAC300
  • 48,601 POSTS
if engine is running yes if check engine light goes on. you'll need a scanner to remove the code if there is one. However, you will not have to clear the codes in order to start the engine. The vehicle should run if you shut the key off, plug everything back in and then start the engine. Basically the PCM will see the circuit is intact again and the codes will go stored and allow the engine to start.
Here are the wiring diagrams requested they are for the fuel pump and engine wiring with a guide to show how you do the testing
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Aug 29, 2016 at 3:28 PM
ANTHONYVAUGHAN
I can't find a (COMPLETE )Fuel pump diagram for this vehicle any where. Hope you can help.
Jun 23, 2020 at 5:35 PM (Merged)
JDL
  • 16,098 POSTS
This may be the same wiring diagram that you have? For the pump itself, gray wire is voltage, black wire is ground. The other two wires are for dash gage. The coil side of relay, dark green wire with white tracer is voltage from computer. Black wire is constant ground. Here are the complete engine and fuel pump wiring diagrams. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Jun 23, 2020 at 5:36 PM (Merged)
SIKNTWISTD
I mounted an external pump but then ended up putting an internal pump my question is will the gas flow through the external pump without the pump hooked up or do i have to disconnect it completely
CARADIODOC
  • 34,308 POSTS
Depends on the type of aftermarket pump. Most high pressure pumps use a pair of toothed gears and are pretty restrictive when forcing fuel through them when they aren't running. With a fuel return system with the pressure regulator on the fuel rail on the engine, that will cause stalling due to low fuel pressure when the highest volume is being pumped, which is during coasting.
MDFIELDS21
Engine Performance problem
2002 Chevy Silverado V8 Two Wheel Drive Automatic 168K miles
My truck just randomly died on me in the middle of the road and wouldn't start back immediately. After sitting for about an hour it started up and made it about 3 miles before I was getting a lot of jerking from the engine not getting fuel. It got towed home and sat there for a day. I started it up and it was running rough for a little bit then started running fine. I took the gas cap off and listened to the pump and it sounded like gargling. I suspected maybe that the gas guage broke and I was outta fuel. I put 5 gallons in it and now it runs fine with just a drive up and down the street. The fuel pump is still making that gargling sound instead of the purge sound right before start up. Will the fuel pump roughly work for this long before completely going out? or is it a possible gas guage issue.
DANAUTHIER
  • 156 POSTS
Yes, the fuel pump may be the issue. The fuel pump and level sending units are replaced as a single componet.
Before replacing your fuel module asmebly check your fuel pressure. If you have a 4.8L, 5.3L, 6.0L or 8.1L your fuell pressure should be 55 - 62 psi with the key on - engine off. If you have a 5.0L or 5.7L the key on - engine off pressure should be 60 - 66 psi. With the gage still attached the pressure should only drop about 5 pounds or so once the key is shut off. If the pressure contiinues to bleed off, check for leaks in the gage, gage connection or fuel lines. IF no external leaks are found, the fuel pressure is bleeding back though the pump and is a symptom of a failing fuel pump.
The noise from the fuel pump also indicates that it may be failing, but some GM fuel pumps can be very nioisey.
Adding fuel when the tank is almost empty may temporarily improve the pump performance. With in the tank pumps the fuel lubricates and cools the pump. If the pump is failing it will heat up, adding the fuel would help cool thepump and make it work a little better for a short time.
All that said, first check fuel pressure to be sure it is correct and holding the presssure.
Let me know what you find and I'll do my best to help.
Dan
QUAGMIRE86
  • 98 POSTS
Yes, check the fuel pressure with a guage. When was the last time your fuel filter had been changed? Also, pull the vacuum line off the fuel pressure regulator and determine if there is fuel in the vacuum line, if so, the diaphram is bad (in the regulator) and needs to be replaced.
14JOHNNYCOPP
I was driving and my truck started sputtering,when I gave it gas it kinda backfired and didn't have any power.I made it home tried starting it and it won't start.could it be the fuel pump
It could be. The easiest way to check is to see if there is adequate pressure at the fuel rail. OR, see if it will start a couple seconds using starting fluid. If it does, the problem is fuel related.
Try that and let me know what you find or if you have other questions.
14JOHNNYCOPP
I checked the valve on the fuel rail,barely any pressure.put a new fuel pump on and all is well,thank you very much????
Glad it's fixed. Let us know if you have questions in the future.
JGROUP1
Is there a restart mechisim for the fuel pump after you run out of gas ?
No there's no such thing unless its a FORD product called the fuel cut off inertia switch. Try checking the fuel pump relay 1st that checks out-test out the oil pressure sending unit which is responsible to power the pump after it starts up. Be advised that the fuel pump relay only comes On for 2 secs to prime the fuel system when it fires this is where the OPSU goes in.
PAUL2DEBA
began checking fuel system because engine does not catch on first try. nothing drastic, just have to turn it over twice usually. 58 psi with key on, engine off. 50 psi with engine running, but does not hold pressure at all after shut down. Drops immediatly to zero. No indication of fuel leaks noted. Book says possible leaking injector or bad check valve on fuel pump module.Engine seems to run smooth enough mileage ok. No check engine alarms shown. I'm guessing leaking injector would give rougher engine operation, so this seems to leave the fuel pump, but would like any recommendations or advice before I spring for a new pump and do the labor. thanks
Have you checked the regulator? Is there any fuel getting into the vacuum hose to it? Finally, allow the fuel pressure to build, take a pair of vice grips and pinch of the rubber hose to the fuel rail and shut the key. See if the pressure drops. If it does, the problem is most likely the it's the fuel pump. If it loses fuel pressure, it's the regulator.
Let me know what you find.
BRANDONSTARN123
2002 silarod fuel pump wont run
Check for power to it. If there is power, replace the pump. Also, check grounds. If there is no power to it, check the fuel pump relay under the hood. See if there is power there.
OUTLAWMOM
  • 6 POSTS
Getting no electricity to gray wire at fuel pump. Where does the wire go?
Nov 26, 2020 at 7:51 AM (Merged)
WRENCHTECH
  • 20,761 POSTS
How are you testing this? It only powers for two seconds when the key is first turned on and resumes when the computer see and RPM signal from cranking.
OUTLAWMOM
  • 6 POSTS
OK, if we run a hot wire to fuel pump it turns on. Someone suggested it could be the oil pressure sensor switch. What are your thoughts on that? Everything else has been replaced and a test light on all plugs and fuses shows juice.
WRENCHTECH
  • 20,761 POSTS
The oil pressure switch is just a redundant power supply to the pump and it can only effect the circuit if it is shorted out. Unplugging it would quickly answer that question. You didn't answer my question about how you are testing this. It only powers for 2 seconds when the key is turned on. https://www.2carpros.com/images/external/58832972.gif
TIMMY LEGENS
I am also having this problem. Sending unit has weak power which I suspect is normal. I am using a tester light. Could the oil pressure switch be the problem ?
You can jump across the oil pressure sender to see if that is the problem. Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response.
