acceleration problems
2000 TOYOTA CROWN
130,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MOS DIZ
  • 13 POSTS
Hey guys,
I am having some issues with my car. When I floor the gas pedal, the car hesitates as if something is holding it back until I lightly release the pedal and then it drives just fine. On normal highway driving, there is no issue. Problem only arises whenever I stomp on the pedal.
Secondly, I am having hard starts especially when the car has been lying around for some time (like hours or a day). This is compounded by the fact that the fuel pump relays keep going bad at an alarming rate, which means that most of the time the car is without a functioning pump relay. There is also no whirring sound on the fuel pump when I turn the ignition on.
Kindly assist.
Jun 22, 2019 at 11:14 PM
Hello
It sounds like you are hot on the trail with the fuel pump not working correctly. did you use a name brand pump when you replaced it? Denso?
This guide can help as well:
https://www.2carpros.com/articles/engine-has-low-power-output
Jun 24, 2019 at 4:18 PM
