fuse number 2 PCM blows
1995 JEEP GRAND CHEROKEE
220,000 MILES • 5.2L • V8 • 4WD • AUTOMATIC
JOEGO
  • 4 POSTS
Fuse number 2 (PCM) blew intermittently for a few days causing engine shutdown, now it blows immediately on replacement. Removed ASD relay still blows. With the PCM Disconnected the PCM fuse does not blow, load side of fuse resistance open. Resistance on load side of fuses is .2 ohms with PCM connected.
Sep 7, 2020 at 2:07 PM
Good evening,
If the fuse fails with the PCM disconnected, then the PCM is internally shorted out. It must be replaced.
I attached the diagram for you. The PCM is the only thing the fuse controls.
Sep 7, 2020 at 3:11 PM
JOEGO
  • 4 POSTS
no, the fuse does not fail with the PCM disconnected.
Sep 7, 2020 at 3:54 PM
JOEGO
  • 4 POSTS
Have visually inspected all engine and under-hood wiring, no faults found. Also did a shake test on wiring with a latching continuity tester again no faults found. maybe I need a new PCM, just would like to know how the PCM divides the voltage from the number 2 fuse before shotgunning parts.
Sep 7, 2020 at 4:08 PM
That fact that the fuse does not fail means the ECM is the issue and must be replaced.
The reason is internal and special equipment is required to find the failure.
Sep 7, 2020 at 4:13 PM
JOEGO
  • 4 POSTS
I Agree it could be a PCM internal fault, but I doubt it because the fuse blew intermittently at first. I think it could also mean a component down line of the PCM faulty. I would like to trouble shoot further before buying an expensive PCM. Replaced PCM fuse still blows.
Sep 9, 2020 at 5:59 PM
If you disconnected the ECM and the fuse did not fail, that eliminates all the wiring up to the ECM.
Did you use a new or used ECM?
Sep 10, 2020 at 3:47 AM
