1988 GMC C1500 Hesitation from a stop
1988 GMC C1500
150,000 MILES • V8 • 2WD • AUTOMATIC
BJH505
Hello, First things first my 1988 GMC Sierra 5.7L with 150,000 milles was running rough at idle but only after warm-up, and after driving SES would pop-up with a Code 32 present. So I replaced the EGR Valve after vaccum testing it, and it wasnt holding vaccum: easy fix.. only now shortly after starting, and driving down the street when I come to a complete stop, and proceed to depress the gas pedal the truck begins to hesitate or sometimes stalls completely! After replacing the egr solenoid, o2 sensor, TPS, distributor cap, rotor, spark plugs, and fuel filter I am at my wits end since I have no other error codes to work with. Thank you for your patience!
Mar 1, 2010 at 7:16 AM
Hi BJH505, Welcome to 2carpros and TY for the donation
Clean out the idle air control valve and EGR valve and test the manifold absolute pressure sensor-also check the fuel pressure
Mar 1, 2010 at 5:39 PM
