1995 GMC Jimmy gas in base pan
1995 GMC JIMMY
TATTMAN111
Engine Mechanical problem
1995 GMC Jimmy 6 cyl Four Wheel Drive Automatic
hi i have a 1995 jimmy and the engine locked up...when i drained the oil it was full of gas now the engine will not meka a full revolution either way...what could it be?
Aug 10, 2009 at 8:58 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
pull the spark plugs and see if the engine will turn over, keep clear of the plug holes as if they are full of fluid it will be ejected with some force, lay some rags over the plug holes just in case, if the engine still will not rotate, you will have a major mechanical failure with a rod or bearing possibly.
mark (mhpautos)
Aug 10, 2009 at 9:04 PM
