2000 GMC Jimmy jerks
2000 GMC JIMMY
118,660 MILES • 6 CYL • 4WD • AUTOMATIC
PCJTASB
recently i have had a problem with my truck when it is hot outside and ive been driving for awhile it jerks during takeoff usually thought the first 2 gears im curious what could be causing this once the truck cools down it doesn't do it im hoping i can discover what the problem is before it becomes more constant . I have checked the fluid its still red and full and the oil was just recently changed
Jul 24, 2010 at 1:33 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 26, 2010 at 1:40 AM
