Heres a good one for you. If you can't find it hanging off the motor anywhere try looking at your oil pan and see if there is a plate-like cover on it about as big around as a filter. It should have a recessed area where there is a nut-like head on it. You might have the kind that is in your pan itself, these have no outer can just the filter element that you change. Not positive but worth a couple of minutes to check out?I recall momma had one like that but it was late 90's so maybe? :roll:
Mar 29, 2006 at 5:58 PM
