1994 GMC Sonoma wheelbearing inspection
1994 GMC SONOMA
JTMILLER
1994 GMC Sonoma 4 cyl Two Wheel Drive Automatic
how do you check your rear wheel bearings with the tires on?
Sep 12, 2008 at 2:55 PM
MERLIN2021
  • 17,250 POSTS
First look inside the wheel, is there any sign of oil on the tires? Do you hear a growling noise from the rear when driving?
Sep 12, 2008 at 3:03 PM
STOLEN75
  • 9 POSTS
jack the car up freeing the "offending" wheel. spin the wheel and listen for noise. Grab the wheel at the top with one hand and the bottom with the other. shake wheel in and out, there should be little to no movement, if your getting excessive play, your wheel bearing is out. If your just getting noise while spinning your tire, its on its way out.
May 24, 2010 at 3:36 AM
MERLIN2021
  • 17,250 POSTS
I think he found it... this is from September 2008... Look for fresh posts, you might get an answer from those.
May 25, 2010 at 2:54 AM
STOLEN75
  • 9 POSTS
i just needed to show i knew SOMEHTHING : ) even if the posts was old, it was more of a spriti booster for me while researching my own question I should have trusted my gut instinct on : )
May 25, 2010 at 4:19 AM
MERLIN2021
  • 17,250 POSTS
OK...
May 26, 2010 at 2:54 AM
STOLEN75
  • 9 POSTS
k...
May 26, 2010 at 3:10 AM
