Hazard light flashes when car is locked
2014 BUICK LA CROSSE
106,967 MILES • AUTOMATIC
TDCHRYSLER
  • 30 POSTS
Hello, so my Buick La Crosse now flashes the hazard lights when it locks, and the alarm engages. Meaning that when the car is turned off, it automatically locks, and sets the alarm, in about 5 minutes or less the hazard lights begin to flash on their own. Even when I press the unlock button on the key fob the lights will continue to flash until I press the hazard light button in the car, then it turns off. I tried taking the terminal off and back on but that did not do anything. I also would leave it and see if it may turn off on its own, but no change. Also, sometimes when it does this the trunk will open on its own or the alarm will just go off. So now I'll have to take the negative terminal off and put it back on whenever I would have to move the car. Does this issue sound like anything familiar?
Jun 28, 2022 at 8:09 PM
Yep, it sounds like the BCM is going out. To be sure let's do a CAN scan which is the future of automotive repair you can get a CAN scanner from Amazon for about $30.00. here is a video to show you how and a link to a scanner from Amazon. I have left instructions on how to change out the BCM in the diagrams below.
https://youtu.be/u-4syLc-ifQ
and
https://amzn.to/3OpAotj for the scanner
Jun 29, 2022 at 12:08 PM
TDCHRYSLER
  • 30 POSTS
Okay, thank you for this information. After having the car scanned the code:
U0140 - Lost communications with BCM.
I attached the image below so that you can see what displayed. Also, is there a way I can get the model/part number for my BCM without having to remove it first?
Jun 29, 2022 at 6:24 PM
Nice work on the scan.
Body Control Module - 13580698 - $198.37 OEM
Please let me know what happens.
Jun 30, 2022 at 8:24 PM
TDCHRYSLER
  • 30 POSTS
Thank you for the help.
Will let you know what happens.
Jul 1, 2022 at 6:43 AM
TDCHRYSLER
  • 30 POSTS
So, update so far, I took the LaCrosse to my Auto Technician for the BCM issue. He then informed me what is causing the BCM to malfunction is my passenger side headlight. That headlight is no good and was wired poorly interfering with the power from BCM. After scanning the car and the checking the BCM, all the codes were coming clear except for the power interference of the bad headlight wiring/receptor (if I am remembering exactly.) So, I will purchase the new headlight and let you know what happens moving forward.
Jul 2, 2022 at 3:08 PM
Nice work, let me know.
Jul 3, 2022 at 12:14 PM
TDCHRYSLER
  • 30 POSTS
Update so far: After installing the new headlight, the BCM was still having issues and has to be replaced along with my under-hood Fuse Box. So, I'm just awaiting delivery of those parts and take it for installation. I will let you know anything further.
Sep 1, 2022 at 6:44 AM
