Head gasket replacement?
2009 FORD FIESTA
300,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
LAEEQ ARNOLD
I need to obtain the torque settings and sequence for the cylinder head bolts, please.
Jun 16, 2025 at 12:28 AM
You will need new cylinder head bolts (10) because there are torque to yield which can only be used one time.
Install the cylinder head gasket, cylinder head and 10 new bolts. Tighten the bolts in the sequence shown in 4 stages:
Stage 1: Tighten to 5 Nm (44 lb-in).
Stage 2: Tighten to 15 Nm (133 lb-in).
Stage 3: Tighten to 35 Nm (26 lb-ft).
Stage 4: Tighten an additional 75 degrees.
Jun 16, 2025 at 11:19 AM
LAEEQ ARNOLD
Thanks Ken.
I have ordered new cylinder head bolts and will continue as soon as they arrive.
Jun 16, 2025 at 12:21 PM
Sounds good, if you need any other help I am here for you.
Jun 17, 2025 at 6:30 AM
