Heated and cool seats do not work
2010 LINCOLN MKX
87,729 MILES • 6 CYL
JIMEDWARDS
Heated seat light goes on for five seconds then goes out same with cool seats light.
Jan 18, 2019 at 3:09 PM
It sounds like the dual seat climate control module has gone out but to be sure let's check the fuses #f16 and #f35. here is a guide to help us get started and the fuse location below along with the wiring diagrams and instructions on how to change out the DCSM seat module:
Dual Climate Controlled Seat Module (DCSM)
Removal and Installation
NOTE: When installing a new Dual Climate Controlled Seat Module (DCSM), it is necessary to carry out Programmable Module Installation (PMI). For additional information, refer to Information Bus. See: Information Bus > Programming and Relearning
NOTE: The air bag warning indicator illuminates when the correct Restraints Control Module (RCM) fuse is removed and the ignition is ON.
NOTE: The Supplemental Restraint System (SRS) must be fully operational and free of faults before releasing the vehicle to the customer.
1. Before removing the DCSM, carry out the appropriate steps in the Programmable Module Installation (PMI) procedure. For additional information, refer to Information Bus. See: Information Bus > Programming and Relearning
2. Remove the front passenger seat. For additional information, refer to Seat - Front See: Seats > Removal and Replacement > Seat - Front.
3. Remove the DCSM.
- Disconnect the 3 electrical connectors.
- Remove the 2 screws.
- Remove the DCSM.
4. To install, reverse the removal procedure.
5. Install the front passenger seat. For additional information, refer to Seat - Front See: Seats > Removal and Replacement > Seat - Front.
6. Install the DCSM software data. Carry out the appropriate steps in the Programmable Module Installation (PMI) procedure. For additional information, refer to Information Bus. See: Information Bus > Programming and Relearning
Front Seats
Without Cooled Seats
Control Module
7E5Z14C724A
168.78
With Cooled Seats
Control Module
9U5Z14C724B
260.20
Rear Seats
Memory Module
5W1Z14C724AA
179.20
Jan 21, 2019 at 12:19 PM
COKEFIRST
  • 4 POSTS
I have a 2015 Lincoln MKZ Hybrid I just purchased. It has 119,000 miles. The heated/cooled seats do not work in the front on either side. The indicator lights for both seats, heating or cooling come on with the 3 lights for either operation but neither seat will heat or cool. The heated steering wheel does work. I checked the fuses, and they are good. Is the heating/cooling module in the driver's seat the control for both seats? It would seem odd that both the passenger seat and the driver's seat would quit working if there is two actual modules.
Apr 11, 2022 at 9:56 AM
Yep, the clue is the steering wheel controls are not working which suggests the clock spring is bad behind the steering wheel which will disable the system. Here is a generic guide on how to replace it with instructions for your car in the diagrams below:
https://www.2carpros.com/articles/steering-wheel-clock-spring-removal
Apr 13, 2022 at 5:18 PM
