Heater and temperature gauge not working properly
2006 DODGE CARAVAN
223,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
BUCKNHORSE
  • 4 POSTS
Hello. I've never ran across this problem before. I'm not a mechanic but I can do a lot of things myself. When I idle my engine temperature gauge works fine and my heater blows the right hot or cold air I want. But when I start going down the road my temperature gauge goes to zero and the heater blows barely warm air at best. But if I say stop at a red light, stop and idle at a store etc the gauge goes back to normal and I get hot air again. Don't know what to check first. Thanks
Nov 9, 2019 at 12:37 PM
MASTERWRENCH
  • 258 POSTS
I would start with your thermostat. If it's stuck open, it's very possible it could be causing this condition. Attached below is the replacement procedure. Also, the attached link shows you how to test a thermostat for proper operation once it's removed from the engine.
https://www.2carpros.com/articles/how-an-engine-thermostat-works
Let us know what you find!
Nov 9, 2019 at 6:37 PM
BUCKNHORSE
  • 4 POSTS
Thanks for the suggestion. I'll put in a new thermostat and let you know what happens. Thanks again.
Nov 10, 2019 at 6:19 AM
MASTERWRENCH
  • 258 POSTS
Sounds good!
Nov 10, 2019 at 6:27 AM
BUCKNHORSE
  • 4 POSTS
Masterwrench, I thought for sure you had me good to go when I saw the old thermostat. I put in a new one and it's doing the same thing. What should we try next?
Nov 10, 2019 at 8:26 AM
MASTERWRENCH
  • 258 POSTS
That's very strange. A thermostat in that condition would have most definitely caused the symptoms you were experiencing. For the condition to have not changed at all by replacing it, seems very odd. Has it improved at all? I would double check to make sure all the air has been purged from the cooling system. Take a look at the video below for more information.
https://youtu.be/j8_MD76LbiQ
Nov 11, 2019 at 7:49 PM
BUCKNHORSE
  • 4 POSTS
Good morning Masterwrench. Everything is still the same since I've put in the new thermostat. I can start it up in the morning and let it idle and the temp gauge goes to about the middle and the air is really warm after a few minutes. But as soon as I start driving the gauge goes to zero and the air coming out is barely warm at all. I live in the country and even at a speed of 20 mph it does the same. It was 16 degrees here this morning and I don't have a garage to try to purge the system. It's supposed to warm up in a day or so and I'll try that. Do you think I may have got a bad thermostat? I didn't test it before I put it in but I also didn't check to see if it was rated for the temperature range I should have. And the box it came in is gone as well. Anyway thanks for your help. Clyde
Nov 12, 2019 at 6:51 AM
It does sounds like the cooling system has an air pocket. I would try to raise the car in the rear as far as you can while the engine and heater are running (fan on high) then raise the front this "tipping" can dislodge the air. Make sure the cooling system is open and be ready to add more coolant. These guides can help:
and
https://www.2carpros.com/articles/car-heater-not-working
Nov 14, 2019 at 11:18 AM
