After some time, the engine overheat indicator lights up?
2007 TOYOTA VIOS
140,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
JAMESNIRMAL
Car somewhat struggles to fully perform when going uphill. After some time, the engine overheat indicator lights up. After checking with the local mechanic, I changed the head gasket (checked the engine head for any leaks. No leaks), changed the thermostat valve, changed engine oil and coolant and cleaned radiator. But I still have the same problem. It does not happen often as before. But the issue is still there.
Jun 6, 2023 at 11:58 PM
It sounds like you have a partially clogged catalytic converter.
Here is a guide to help confirm the problem:
This guide may help as well:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Please go over these guides and get back to us.
Jun 7, 2023 at 11:38 AM
