Limp mode
2005 NISSAN ALTIMA
136,132 MILES
RICKKK
  • 4 POSTS
i think it went on limp mode. i push on the gas no response. also the lights on the dash go crazy. i cannot go past two miles.
Mar 18, 2019 at 7:56 PM
Good morning,
Is the check engine light on?
You can go to a parts store and have it checked for free. Once you know the code, then let me know so I can narrow down the area of failure.
Mar 19, 2019 at 5:50 AM
This is a common problem and 9 time out of 10. the throttle bore is dirty which causing the computer and throttle actuator to lose correlation making the car go into limp mode. Here is a guide that will help:
https://www.2carpros.com/articles/reduced-power-limp-mode
Mar 19, 2019 at 1:11 PM
RICKKK
  • 4 POSTS
Code p1065.
Mar 19, 2019 at 4:33 PM
Got it.
I attached a possible issue below. You need to verify the fuse listed for power on both sides.
If there is power, then looks like you have a failed PCM.
Mar 19, 2019 at 4:41 PM
RICKKK
  • 4 POSTS
I am going to replace the ECM.
Mar 19, 2019 at 7:36 PM
Keep us updated.
Mar 19, 2019 at 7:39 PM
RICKKK
  • 4 POSTS
No problem.
Mar 19, 2019 at 10:09 PM
Make sure you have it flashed to your VIN number.
Mar 20, 2019 at 5:04 AM
