can you tell me the torque specs. on 94 1.5 head bolts and intake manifold?
Dec 3, 2008 at 7:55 PM
BLUELIGHTNIN6
CERTIFIED EXPERT
Great. Thanks for that.
It looks like there are several engines used in the Civic DX. The engine serial number is located on exhaust side of engine block, below cylinder head near bellhousing. The first 5 characters of engine serial number identify engine type. Please take note of your serial number before following instructions below, although the tightening sequence remains the same, the torque specs are different for each engine type in the Civic DX.
Here is a video to help you see how to use a torque wrench.
https://youtu.be/juOClONIWeY
SOHC ENGINES for Civic DX
Cylinder Head Bolt Specs.:
Engine Type D15B7 & D15B8 :
Stage 1 - 22 ft lbs (30 Nm)
Stage 2 - 48 ft lbs (65 Nm)
Engine Type D15Z1 & D16Z6
Stage 2 - 53 ft lbs (73 Nm)
Cylinder Head Bolt Tightening Sequence
Intake Manifold-To-Cylinder Head Nut Specs.:
17 ft lbs (23 Nm)
Cheers
Dec 4, 2008 at 12:30 PM
ALFRED AMADO
MEMBER
1 POST
What is the torque sequence for the head bolts, and PSI?
Nov 17, 2018 at 11:35 AM
(Merged)
MHPAUTOS
CERTIFIED EXPERT
Step one 30 Nm Step two 65 Nm.
Image (Click to enlarge)
(Merged)
SKKDKKDK
MEMBER
1 POST
what is the head bolt torque sequece and ft/lbs of torque on a 93 hond civic 1.5l
I just completed a valve job, including re-surfacing the cylinder head. The head bolts were torqued properly according to the Chilton's Repair Manual. My question is: Should the head bolts be RE-TORQUED after the initial run-in period of 500-1000 miles?? The Chilton's Manual made no mention of that.
Feb 3, 2019 at 8:37 AM
(Merged)
CARADIODOC
CERTIFIED EXPERT
Normally not unless the instructions with the head gasket specified differently. Was the head checked for warpage? If it had less than .002" irregularity, resurfacing isn't necessary but it will help the gasket bite and seal better. If there was a lot of warpage, overhead cam heads have to be heated and straightened, otherwise the cam journals will still be out of alignment.
(Merged)
YUNGBLUD316
MEMBER
1 POST
Hi i was wondering what the head bolt sequence for a 95 Honda civic would be?
(Merged)
BMRFIXIT
CERTIFIED EXPERT
1.5l engine
1.6VETc
(Merged)
HONDA TECH 1818
CERTIFIED EXPERT
CYLINDER HEAD BOLTS TIGHTENING SEQUENCE
Tighten the cylinder head bolts in two steps.
1st step : 30 N·m (3.0 kg-m , 22 Ib-ft)
2nd step:
D16Z6, D15Z1 engines:
73 N·m (7.3 kg-m , 53 Ib-ft)
D15B7, D15B8 engines:
65 N·m (6.5 kg-m , 47 Ib-ft)
(Merged)
SKITZ
MEMBER
1 POST
I have a 1.6 16v esi v-tech civic here and i have just stripped the head down to fit a new head gasket. The engine has 146,000km on it. I was looking to know what the torque settings are for the bolts on the head and what is the sequence for tightening them???
