1996 Honda Civic Cream in my intake and oil
1996 HONDA CIVIC
BTTF11985
  • 23 POSTS
1996 Honda Civic 4 cyl
I have a 96 honda civic ex 1.6, 5spd. I just bought the car and I have had to put in about 12-24 ounces of water in the radiator after about 40 miles of driving and I dont see any leaks, also there was some kinda flaky stuff in the radiator water? I put in redline water cooler cause there was not much coolent. When I 1st start the car it idles about 1100 and it drives fine, I noticed this cream stuff on the drive way and it was comming from the airfilter, (witch is not stock it has a injen air intake system) and it went up and in the throttle body, After further inspection I noticed this cream stuff under the oil cap a lilttle on the oil dip stick and stuck on the walls of the valve cover and on and around the spark plug. I dont see any in the radiator the water is clear. Can this be a blown or pertial blown head gasket? Thank You for your time and help
Apr 12, 2008 at 4:45 PM
Get the cooling system block and pressure tested this will tell you something about the creamy looking substance-could be headgasket cracked head or block-
And also check out the PCV valve
Apr 12, 2008 at 4:54 PM
BTTF11985
  • 23 POSTS
I took off the #1 or #4 wire it had the cream stuff all around it and the plug. I drained a little oil and it was a greenish color with some cream stuff not that much? What should I also replace if I have to replace the head gasket? like timming chain valves ect... Thank You!
Apr 12, 2008 at 9:18 PM
Not familiar with this Honda 1.6 -but if it has a belt and water pump behind the front cover replace it-also the oil pump.
Apr 13, 2008 at 2:59 PM
BTTF11985
  • 23 POSTS
Update. I took the head off and there was a new gasket on there, I took the head in to a machine shop and they told me it had already been re-surfaced and there was also a heli coil in the #3 cylinder so do you think my problem with loosing coolent in the oil lies in the head? Cause there is no water on the ground to indecate a crack in the block?
Apr 16, 2008 at 2:53 AM
Coolant in the crankcase something is leaking get the head pressure tested/magnafluxed for hair line crack or try another headgasket and go from there.
Apr 16, 2008 at 9:28 AM
BTTF11985
  • 23 POSTS
I had the head pressure tested and they found a crack. it was cheaper 2 get another head so my question is how do I set it 2 TDC? On the block the pistons are #1 Up to top of block#2 down #down and #4 up to top of block. Thank you for all of your help, This has been a nightmare.
Apr 18, 2008 at 10:45 PM
Put no.1 piston on its compression stroke-then line the camshaft and crankshaft sprockets then put the belt/chain on-
Apr 19, 2008 at 7:57 AM
BTTF11985
  • 23 POSTS
so on the #1 piston I have it up to the top correct? On the head lining the camshaft and crankshaft sprocket do you just line them with the #1 so when the piston comes down on #1 the intake should start to open on the #1?
Apr 19, 2008 at 3:02 PM
Put no.1 piston on compression stroke/TDC Line the sprockets as you see below then install the belt-
https://www.2carpros.com/forum/automotive_pictures/12900_timing_16l_1.jpg
Apr 19, 2008 at 4:23 PM
BTTF11985
  • 23 POSTS
So it does'nt matter how many times I turn the sprocket on the head just as long as I line up the up mark with the white mark? Thank you very much!
Apr 19, 2008 at 8:36 PM
