2001 Honda Civic removing crankshaft pulley bolt
2001 HONDA CIVIC
116,000 MILES • 4 CYL • 2WD • MANUAL
ALLEN PICKELL
I've used a professional 3/4" air impact wrench to try to remove this silly bolt with no success. I am thinking this must be the result of factory locktite overkill. I know locktite weakens without a lot of heat. My question is, am I right and do you have any ideas on how to get the bolt hot enough?
Oct 21, 2010 at 1:41 PM
DOCFIXIT
  • 18,828 POSTS
Try a series of tighten -loosen-tighten-loosen
Oct 21, 2010 at 2:07 PM
ALLEN PICKELL
Couldn't remove this bolt with a 3/4" professional air impact wrench. My guess is I am dealing with a factory locktite overkill problem. I need to know if I am right and suggestions on how to heat the bolt hot enough.
Oct 21, 2010 at 2:13 PM
DOCFIXIT
  • 18,828 POSTS
Would not use heat sreies of impact will break Locktite loose
Oct 21, 2010 at 2:28 PM
