Rear light and brake lights stay on
2003 HYUNDAI ELANTRA
66,000 MILES • 4 CYL • FWD • AUTOMATIC
LESLIEANNMARCOBREWSTER
Rear light and brake lights stay on when car is off. Brake lights do not work?
Jul 27, 2010 at 6:59 PM
KHLOW2008
  • 41,814 POSTS
Hi leslieannmarcobrewster,
It sounds like you have a hazard switch or flasher that is out but to be sure here is a guide to help us test the power and grounds and the brake light wiring diagrams to help you do the tests.
Check out the diagrams (Below). Please let us know what happens.
Aug 1, 2010 at 10:17 AM
ZANYJB
I did some checking and I had a bad hazard switch
Dec 31, 2018 at 12:02 PM
TEDNORRIS
all my brake lights are staying on even after I turn the car off and exit the car.
I have taken all the fuses out just to see if that would help and nothing changed.
can someone advise?
Thanks
Dec 31, 2018 at 12:03 PM (Merged)
Inspect and test the brake switch
TEDNORRIS
Thank you very much!!!
HYPERROY
Brakes problem
2001 Hyundai Elantra 6 cyl Front Wheel Drive Automatic
Need to know why brake lights are staying on when car is off ?
BLUELIGHTNIN6
  • 16,542 POSTS
brake light switch, above brake pedal, has failed.
SATURNTECH9
  • 30,869 POSTS
I would be checking your brake switch that's where i would start.
SAMURAIBLUE
Electrical problem
2002 Hyundai Elantra 75000 miles
2002 Hyundai Elantra... After driving home one night, stopped at the gas station and noticed that the brake lights were on while the car was off.
Drove home, and noticed that the brake lights were still on, even after the lights were turned off and the engine turned off.
When pressing down on the brake pedal, the central brake light (in the back window) does not turn on, and while driving, its as if the two taillight brake lights are always depressed.
BLUELIGHTNIN6
  • 16,542 POSTS
most likely culprit is sticky/faulty brake light switch, located above brake pedal.
BRENB1961
A small magnet the size of 2 pennies will work great. That's what I had my husband use for a temporary fix.
SIYA
Hi, my brake lights are always on even after I turn of the engine. this had happened after we changed back shock.
HMAC300
  • 48,601 POSTS
it cold be a shorted wire doing this but have it scanned for codes by a mechanic as it may be an ABS problem like a bad sensor or shorted wire.
DADJOYNER
1998 Hyundai Elantra
what would cause the brake light to stay on with the car turned off and the peddle not being pressed?
Inspect and test the brake switch.
TX_LATINA02
The brake lights on my car stay on. They were bleeded, yet they still stay on.
MHPAUTOS
  • 31,937 POSTS
Hi there,
Check the brake light switch is not faulty, it is on top of the brake pedal under the dash.
Mark (mhpautos)
BRYANDKING
When I turn off the motor and remove the key, the brake lights remain on. I have checked what I believe to be the ground near the rear of the trunk. At this time, I am pulling the fuse so that my battery won't be drained. Do I have a short somewhere maybe?
Dec 31, 2018 at 12:04 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
Hi there,
Check that the brake light switch at the top of the brake pedal not holding on.
mark (mhpautos)
MSORKIN
all of a sudden my 2 brake lights and third brake light continue to stay on even when the car is totally shut off
replaced all 3 bulbs and checked fuse box under dash by driver's side
any ideas
Check the brake light switch adjustment. It's on the top of the brake pedal.
RLM89
hi i have a question resolving my car. it has to do with my break lights staying turned on when my car is off. i need to know how fix this problem without myself alwways have to pop the hood and take off my battery wire
thanks alot
MASTERTECHTIM
  • 4,750 POSTS
replace or adjust the brke light switch. its located right above the brake pedal and is causing your problem
RLM89
thanks alot... so far i got the same answer from 3 different mechanics and im sure this is the problem... thanks again
rob
KINGWADE5
Why do my brake lights stay on even when i am pressing the pedal?
MHPAUTOS
  • 31,937 POSTS
Hi there,
This will normally be a faulty brake light switch which is located at the top of the brake pedal under the dash.
Mark (mhpautos)
if your brake lights are coming On with out stepping on the brake pedal-adjust or replace the brake switch.
2CP-ARCHIVES
  • 4,540 POSTS
1993 Hyundai Elantra. Just recently I discovered that my brake lights will not turn off. When I lift the brake (from underneath) just a little, the lights will turn off. But, when the brake is left in the normal resting position, the lights stay on. Is it possible that the spring that pulls that the brake up while not in use is worn out and that there is not enough tension to pull it high enough to where the lights won't turn on? If so, do I need to order that part from my dealer?
2CP-ARCHIVES
  • 4,540 POSTS
It sounds as if the brake light switch needs to be adjusted. It is located on the brake pedal leakage up under the dash.
BUBBADAM
Stop Everything! there was recalls on the newer types of of these cars and the problem still exists back then, before replacing the Brake Switch First is to check if your Brake Light Switch Stopper is not missing evidence of Broken rubber or plastic on the drivers floor is a indication. this is a very common problem with these types of cars and I'm not only saying Hyundai but also honda and other models has also same problem.
on the 2004 Hyundai Elantra The stopper is located on the Brake Pedal arm and if its missing the brake light switch will not turn off because the Plunger will go through the hole where the stopper was and not turn the switch off.
A quick fix is double sided tape and a penny but better to fix it properly get a new stopper and replace it than risking your life.
Aug 31, 2019 at 5:56 AM
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Aug 31, 2019 at 12:40 PM
SOFTBALL42
brake lights stay on for my 1993 hyndai elantra. i already replaced the switch, could it be the fuse?
Aug 31, 2019 at 12:40 PM (Merged)
Check for power before and after the brake switch-got both the brake circuit is open between the switch and the bulb socket
