Ignition coil module suspected faulty, can i switch modules around?
1998 BUICK LESABRE
252,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
ALPHAA10
  • 232 POSTS
After having ordered and installed a new ignition coil module, bought in a clearance sale at a discounted price my P0304 code did not disappear, and the code analysis suggested I buy a new coil.
Although I can buy a second coil and see whether it sends another code when installed in the same position, it occurred to me to switch positions of a "known" good coil with the suspected bad coil. If I still get a P0304 or similar, that means my problem is probably not the clearance sale coil I bought, but a spark plug or plug wire.
And if I get a P030x code for the new cylinder location of the discount sale coil, that means the coil is faulty.
Is this analysis practical?
Mar 13, 2024 at 2:16 AM
STEVE W.
  • 15,116 POSTS
Yes, that is a practical option. Generally, what I suggest is to swap the coil to a different cylinder. Then swap the plug to another one as well. Then see where the code shows up next. So, if you start with a P0304, swap the coil to 3 the plug into 2 and now you have a P0302, it's likely the plug. Same with the coil. However, that car uses a single coil to fire two plugs at the same time in a waste spark system. If you get a misfire for one cylinder it should also show for its mate. In this case that would be cylinder 1. As such I would suggest it's not the coil. It can be the wire or plug, but it could also be something internal.
Mar 15, 2024 at 4:39 AM
ALPHAA10
  • 232 POSTS
Steve, thanks for your response.
In your example, you suggest both the coil and plug can be moved around independently, so long as spark plug wires always go to the original ignition module position, whatever coil or plug has been placed there.
Just wanted to be sure I understood you..
Mar 15, 2024 at 10:33 PM
STEVE W.
  • 15,116 POSTS
In your case I doubt it's the coil. Why? Because each of the 3 coils fires 2 spark plugs at a time. So, with a P0304 code you would also have a P0301 code if the coil was bad. The coils can be swapped around as long as the plug wires are kept correct. What I like to do to save aggravation is to mark them with white paint markers. On the engine the lowest coil should be cylinders one and four. The center coil is cylinder two and five and the top coil is three and six. The plug wires just need to go to the correct coil.
Mar 16, 2024 at 3:15 PM
ALPHAA10
  • 232 POSTS
Steve,
That is what I thought, too, since I should have had dual codes for the same coil-- one for cylinder 1 and one for cylinder 4.
Tiring of my frequent trips to the auto parts store to run scan after scan, I have purchased an OBD2 scanner, which arrives next week. Until now, I was okay with having the auto parts store do my scans-- saving me the cost of a really good scanner. But one day recently, when I asked a store employee to make sure to clear codes after his scan, I was told he cannot clear customer codes, as store policy. This is almost certainly true of other auto parts stores, as well, which might claim that clearing codes is a "legal hazard".
When I realized the in-store scan service is essentially worthless (except to suggest further parts sales), I went to eBay to purchase a comparatively good scanner. Unfortunately, it's scan, or be scammed.
Mar 16, 2024 at 10:51 PM
STEVE W.
  • 15,116 POSTS
True, these days if you want to be able to do your own work you need a scan tool. You are lucky in that you have one that doesn't need it for things like brake or steering work or to reset the oil life or to set battery parameters, so the charging system works. But a scan tool that can handle more than just reading codes is still very much needed if you don't want to throw a lot of money away. A good source of information is also very helpful. If you want to learn how to use the new toy I can give you some links. What tool is it? I could look and see what it can do and give you tips on where to find tests and results. Unfortunately, the scan tool world likes to play with things and the OEs don't help when they sue because of someone using the names they call parts. As such you find things like the Forward Control Module, Totally Integrated Power Module, Body Control Module and Generic Electronic Module all being the module that does the same jobs in different makes!
Mar 16, 2024 at 11:08 PM
ALPHAA10
  • 232 POSTS
Steve,
Yes, I would like to receive tips and links for the new toy.
Thanks!
New scanner link:
https://www.ebay.com/itm/225995139503
* Since few things are completely satisfactory, this product may have some limits, or even problems. Since I can alter my purchase choice within the next 14 days, I certainly would appreciate any points from your experience about using such a scanner as linked above.
Mar 17, 2024 at 10:12 PM
STEVE W.
  • 15,116 POSTS
That one is a bit more advanced than a basic code reader. Given the level of diagnostics in your Buick it should be able to handle reading the engine codes, looks like it also has basic explanations as well. Should take the place of the free scans and "helpful advice" the parts stores give you. Pair that with this site and you have some good tools to start. You might look at both Alldata and mitchell1 service information systems. Both are used by shops and dealerships and each offers DIY subscriptions where you get access for one vehicle for a set time. Mitchell1 ( https://eautorepair.net/ ) for example is $20 a month, $40 a year or $60 for three years. Alldata is more money and basically the same information. The thing about both sites though is that you can print out the pages Now if you were to get the one month package and use a windows computer that does the print to pdf printing you could have an entire pdf version of the factory service information saved on your computer. Including the codes, tests, and the code setting criteria which can be very helpful. Say you have a P0304 code, you would get a chart like the images attached to give you a testing process to use. Some of the steps in those charts are actually useless because the tests don't really tell you anything useful but they can teach you about the processes. Now if you really want to learn some more interesting ways to really test the various sensors and know after testing if the part is good or not, there is a book available written by Paul Danner (aka Scannerdanner)
https://www.scannerdanner.com/buy-the-book.html that really dig into the various pieces and sensors and how they work and what things really work in testing. Then you can be the one in the family and friends group that folks come to when they have a light on in their vehicles! Then you might decide on a mid-range tool, or even opt to jump in the pools deep end with a pro level scan tool with full bi-directional abilities that can handle every system on 99% of the vehicles around you, something like this one:
https://www.topdon.us/collections/professional-series/products/phoenix-max?variant=44112567271702
Mar 18, 2024 at 12:54 AM
ALPHAA10
  • 232 POSTS
Steve,
Thanks for the prompt response, the material you sent is definitely of interest, and I plan to visit both the Mitchell and AllData sites, and eventually sign up for one of them. I presume both cover the entire spectrum of automotive repair, from drive train through brakes and electrical.
Excellent suggestion for putting the lessons into PDF for digital storage, and printing, as required. Even my phone can Bluetooth aboard the same PDFs from a PC or internet connection, I believe, though the image view under the hood probably will be more restricted
Since all of us today are joined at the wallet to our cars, this is the way that seems most practical in terms of expense, and time spent. Yes, it would be easier to have my car issue serviced by somebody with a TopDon $3,400 scanner, but that person also must pay for his investment, and will bill me for donations.
As one still at the shallow end of the pool, working with an edgy old Buick, full of switches but not that much digital switching, I have my hands full, at the moment.
(1) Things to remember (all cannot be written down) (2) Things to avoid, overlook or forget (consumer myths) (3) Procedures to learn, and later review (4) Better ways to manage even basic procedures (5) What no shop or auto store will tell a consumer, and what all the shops and stores claim. (6) Things I should write down, since that must do until I gain better understanding from experience.
Is Paul Danner's book something I could understand on a practical basis? That is, could I translate his explanation into my own situation?
Mar 18, 2024 at 3:42 AM
STEVE W.
  • 15,116 POSTS
Mitchell is the better deal in pricing and yes, they cover pretty much all of the service info you may need. I use 4 different services myself because just like scan tools they each have different features. However, for the DIY that would be very cost prohibitive. Just like buying a pro level scan tool wouldn't be for the average DIY simply because of the cost per use factor. Pauls book is more if you decided to go beyond your vehicle in terms of learning how the various sensors and circuits work. It isn't casual reading but if you decide to go farther it can help.
Mar 18, 2024 at 8:52 AM
ALPHAA10
  • 232 POSTS
Steve, I got the scanner, and, prior to doing a new scan, cleared all previous codes stored in the BCM successfully. (I kept printouts of all previous auto store scans). So far, no codes have appeared, but I must wait a few weeks before presuming the engine is okay, again.
At this point, if another code appears, I can add the item(s) the code implies or indicates, then clear codes and rescan. If the same code disappears, then my problem has been "solved", at least until another code appears.
In any case, I probably should consider the Mitchell1 subscription you suggest-- the scanner, itself, is only a guide to diagnosis and not a full diagnosis.
Mar 25, 2024 at 12:29 AM
STEVE W.
  • 15,116 POSTS
Sounds like you are going to take my job soon lol. You can always ask for help here, but getting the service information so you can read it yourself can help. Especially if you look up a code and see what things cause it to set. Understanding that can save you time and money.
The codes themselves are nothing more than the computer saying "Hey you I have a bad reading in this part of my system" nothing more. Other than a very few very specific OEM codes, none of them really tell you to replace any parts, although on the newer vehicles they are narrowing it down much better. So, take your car. It shows code P0304. That means it thinks that cylinder 4 isn't doing its job. It can tell that using a few indicators. One is the crank position sensor; it knows that at a certain rpm it should see a set time between each tooth on the reluctor. If a cylinder isn't firing correctly, it sees the wrong time. It also looks at the current and voltage as it fires the coil, again it is programmed to see good or bad. Nothing else.
However, it can't see some things that could cause that code. For a cylinder misfire there are many things that can cause it. A bad coil, a bad plug, a burnt valve, low compression (caused by damage to the bore, piston, piston rings) A bad injector and bad valvetrain components.
You go to the parts store, they are going to tell you, "Change the plugs, OH and we sell them". Didn't help, okay change the coil, will that be cash or charge? Oh, gee that didn't help, probably a bad injector then, you should really change them as a set so they all flow the same, Will that be the left leg or arm today? What, it still has a misfire, Oh I'm sorry, here is the name of a good shop, it must be internal damage and they can handle that.
Now in many instances it doesn't take long for a good tech with experience to diagnose the problem with minimal labor. And in reality, most people could learn those same skills or find a video on how to test the items without a lot of special tools. For instance, low cylinder pressure, get in the car, hold the throttle to the floor and listen, you should hear a steady cadence as the cylinders cycle through. If you hear it turning over with a lope, Like this car around the 4-minute mark.
https://www.youtube.com/watch?v=-YgKpfpr3CM
You know it's an internal problem. That basically tells you the engine needs work. For the external parts (coil, wire, plug) a simple test light can help tell you if there is power to the coil, if there is a timing signal to the coil and if there is spark. There are a lot of fancy tools that can help as well but a simple test light and your own ears can do a lot. And you didn't chase the rabbit...
Now a bad parts store or shop might look at this single cylinder misfire and tell you, OH you need a fuel pump, or you need a new ECM and those will fix it. The average person would likely say OK do it. However, if you think about it a minute you will realize, you have 6 cylinders, that pump supplies fuel to them all, how do you get a single cylinder misfire with a bad pump? Then you need a new ECM? HMM, the coils in your car fire 2 cylinders at the same time, but only one cylinder is misfiring, that means the coil is getting the signal to fire from the ECM, so it's not the ECM. Probably more than you wanted to know but it also gives you an idea of how to gauge a shop or even a parts store.
Mar 25, 2024 at 11:15 AM
ALPHAA10
  • 232 POSTS
Thanks, Steve, that definitely confirmed my new direction.
Mitchell1 will see me, buy a subscription, soon.
From now on, neither my scanner nor the local auto parts store "expert" will be my primary source.
Mar 25, 2024 at 5:59 PM
STEVE W.
  • 15,116 POSTS
My general progress is, Scan vehicle. Note all codes. Research those using code setting criteria, wiring diagrams and other info. Then develop a plan of testing the items in question based on what those show.
Mar 25, 2024 at 6:38 PM
ALPHAA10
  • 232 POSTS
When I visited Mitchell1, my first question was about the subscription format. When I tried to "test-drive" Mitchell1 before deciding on purchase of a plan, I could not examine any information under "demodiy" without committing to a plan and paying for it, first.
Since I have multiple cars,
(1) must I choose a single vehicle for my entire plan term, or
(2) can I login under my plan credentials, then choose any vehicle I need to research for that single session?
The reason I ask, if professionals with many vehicles to service must have information for multiple vehicles available under their plan term, it made sense that any single vehicle's information is available during a single session (but for that session only).To obtain information on many vehicles, I must login under each vehicle, one session at-a-time.
Although I have left a query with customer service, your experience can help, here.
* My fascination with the new code reader was short-lived. For example, after replacing the old EGR unit under code P0401, I cleared that code, and tested the new unit under city driving for about two days. Nonetheless, I got the same P0401 engine code as before, with the code reader's brief text description, "Insufficient exhaust gas recirculation "A" flow detected".
Obviously, even such "simple" matters become complex, quickly.
Mar 31, 2024 at 4:24 AM
STEVE W.
  • 15,116 POSTS
The DIY versions only allow a single vehicle per subscription. So, you would select a plan for a 98 LeSabre and you would need a different one for a 2005 Mustang. That is one of the drawbacks to the DIY side. The upside is the cost is FAR less than what I pay for access per month, but I have access to all the makes and models they cover, same with Alldata and Identifix access. It's one of the reasons 2CarPros exists. We want to help DIYs and pros with repairs and providing the information to do that is part of it.
I generally point folks at the DIY services when they have a single vehicle and want good information on that vehicle. Unlike some manuals that cover multiple versions the info on those covers only that year, make, model and engine. As an example, Haynes offered a manual for the S10 Trucks that covered from 82 up to 94. They had on the cover that the manual was based on a complete tear down. The BIG catch to that is that in those model years GM used 4 different fuel systems on 9 different engines and 10 different transmissions! So, you are looking at the book trying to remove the plugs from a 151 4 cylinder is much different than on the 4.3 V6. Haynes however covers that with "Others similar"
Are they useful? Somewhat, but not for some of the specific things you might need.
On this site we try to keep things simple and have each question as an individual item to make searching easier. However, P0401 in a 3.8 can be caused by a bad EGR valve, but a more common reason in older engines is carbon build up in the EGR passages. Carbon blocks the ports and low or no flow is the result. They can be cleaned out using a chunk of small cable and a drill. Sort of like a Roto-Rooter.
Mar 31, 2024 at 7:44 AM
ALPHAA10
  • 232 POSTS
Steve,
Thanks for that. The reason I did not try the speedometer cable method is I did not know about it, at the time. But that possible remedy for the old valve would not explain the failure of a new EGR valve.
Immediately after new valve installation, I got no codes for about 20 miles of driving, but now the P0401 is back, and has remained after even two code erasures. No other codes have appeared, so at least, the diagnostic is down to one code.
What diagnostic do you recommend for a new but suspect EGR valve (electrical)? If the fault were carbon accumulation, this seems too soon in its service life-- 20 miles and then a repeated P0401. I can check for adequate 12v power, for example, with a simple VOM, but that doesn't say much about the electrical internals of the valve.
My appreciation for explaining the Mitchell1 pricing policy-- as you understand, I would not have visited Mitchell, had I not been interested.
Apr 1, 2024 at 1:27 AM
STEVE W.
  • 15,116 POSTS
I would expect the carbon to be the issue. EGR doesn't work all the time, it only flows small amounts most of the time. A partly blocked passage wouldn't set the code, however when the system opened the valve up for more flow and the O2 sensors don't see the change they expect in the exhaust gasses you get the code. Sort of like breathing, if you breath shallow you could breath through a straw, now go out and work hard to where you are gasping for breath that straw is going to be a blockage. I would start by cleaning the passages. I generally do it the hard way, earplugs, safety glasses and disposable coveralls with hood. Then pull the EGR off and get the cable in place and start the engine, start running the cable and let the exhaust blow the crud out of the tubes.
Yes the pricing on most of the service information sites are very high. If I add up the costs of service information, scan tool subscriptions, and training classes it works out to almost $1,000.00 a month, without touching a single vehicle.
Apr 1, 2024 at 9:17 AM
ALPHAA10
  • 232 POSTS
Almost $1,000 monthly? That shows a serious commitment to staying in business. Clearly, you love your craft (although most people admit to a love-hate relationship).
Liked your explanation of EGR failures. Now, I understand why even a new EGR offers no improvement-- the valve is not the entire tube system involved. Constricted flow occurs upstream, not in only the EGR valve, itself.
And now I understand about wearing safety glasses, coveralls and earplugs in your method of clearing EGR tubes. For safety's sake, I plan to put on a cheap but full body suit (usually washable), and wear a particle mask against the cloud of fine carbon debris that may emerge from this 250K Buick engine. (The finer carbon emissions are what epidemiologists blame for higher lung cancer rates.)
BTW, in this context, do you ever scrub down your own engines with foaming or spray liquid engine cleaner, just to make it easier to work on?
* I am headed for a (Mitchell1) subscription-- pay day is next week.
Apr 1, 2024 at 1:10 PM
STEVE W.
  • 15,116 POSTS
I try to avoid doing much cleaning. Instead any seepage or leaks get repaired before it's an issue. Removing carbon is a messy job, these days I don't get a lot of those, it's more doing the valves in GDI engines. Those get walnut blasted and I use a special machine that's part sandblaster and part vacuum.
Yeah it's like many other codes, they can be sneaky. For instance a lean code, it could be a vacuum leak or a bad fuel pump with low pressure. Or it could be excess EGR or in an earlier TBI system a bad injector. Most codes have multiple possibilities. The more modern vehicles have more computer power and more sensors and also have a lot more error codes. Some like BMWs tend to roll off the delivery truck with error codes, usually for really stupid things, like the passenger window went up slow, or the left turn signal is blinking the wrong timing. Those can be fun. Your car is much simpler, I'd try to keep it for another 100K if you can.
Apr 1, 2024 at 8:06 PM
ALPHAA10
  • 232 POSTS
Since no car is without eventual problems, I prefer my cars to be simple as possible, sparing me time and energy with required and occasional maintenance. The 1998 Buick LeSabre and my other two cars are more than 20 years old, and I plan on keeping them "forever".
Gadgetry is fascinating, but as you point out, there is always something to diagnose and adjust/repair/replace.
Apr 1, 2024 at 10:09 PM
STEVE W.
  • 15,116 POSTS
What is worse is that it's already difficult to get replacement modules for 10 year old vehicles. One of the hidden items the automaker EV deal with the feds is that they would stop making parts for the old vehicles! That way people would be forced to buy a replacement vehicle. It's why I have gone out and bought a few parts cars and stripped them for parts. I plan on completely rebuilding one and doing as much rust prevention as possible and having it ready for the future. May even put a couple other vehicles into storage as reserves.
Apr 2, 2024 at 10:35 PM
ALPHAA10
  • 232 POSTS
OEMs are required to keep parts available for 10 years, but beyond that, the rest is largely aftermarket pressure on remanufacdurers/refurbishers to keep obsolete parts in stock.
Apr 3, 2024 at 1:25 PM
STEVE W.
  • 15,116 POSTS
Sort of true, there is an agreement to keep parts "available" for 10 years after the end of production of a vehicle, but there are a lot of exemptions to this as it isn't a law, just a handshake agreement made so auto makers could secure some items in a federal contract.
The only real law is the Magnuson-Moss warranty act, and it states they have to maintain parts availability for the length of the warranty. The other is the emissions warranty for those items covered under it.
That bit Ford a few years ago, a lady had bought a new truck and the heater control head failed real close to the end of the warranty. She went to Ford and they basically said, "Yep it's bad, but we no longer have that part, Sorry" Ford at that time had a real grocery list of options that added different switch options to the panel. The option package she had was like 1 of 10 built. She went to court over it and won, Ford ended up sending the control head to the company that made it and they built 100 replacement boards, but those were equipped with all the switches and became a "universal replacement". The switches that were not needed just didn't have the working buttons in the trim.
It can drive shops up the wall for some things.
Apr 3, 2024 at 2:28 PM
ALPHAA10
  • 232 POSTS
Thanks for that clarification about enforceable requirement vs a "handshake agreement". Put differently, OEMs try to play games with at least some regulators at the federal and state levels, and sometimes get away with it.
The recent attention to Boeing's 737 SuperMax shows FAA used to call the aviation OEMs and airline companies "clients" and "partners", and sometimes they were left to meet FAA requirements by regulating themselves.
What could go wrong?
Of course, regulation itself is not necessarily the problem, but the failure to regulate intelligently, for the intended effect. As with troubleshooting any system, the problem frequently is "upstream"
* BTW, I am set to search for a used speedometer cable. How long should it be?
Apr 5, 2024 at 3:10 PM
STEVE W.
  • 15,116 POSTS
There are a lot of those "agreements" in the auto manufacturers world.
If the speedo cable housing is intact you can get the inner cable as a universal item that you cut to fit and add an end to it.
Apr 5, 2024 at 4:07 PM
STEVE W.
  • 15,116 POSTS
Maybe, the part number there doesn't show exact fitment. The inner cable might be correct length.
Apr 18, 2024 at 8:37 PM
ALPHAA10
  • 232 POSTS
What length should I select?
For confirmation of correct eBay selection, if seller does not specify length, I can contact the eBay seller directly.
Apr 19, 2024 at 12:34 AM
STEVE W.
  • 15,116 POSTS
I don't show the length or part number in the service information. I don't even recall a 98 as having a mechanical speedometer but an electronic one but it's been a while.
Apr 19, 2024 at 1:22 AM
ALPHAA10
  • 232 POSTS
Okay, Steve. I appreciate the effort. Thanks!
Apr 19, 2024 at 7:28 PM
ALPHAA10
  • 232 POSTS
Steve, preparing for the operation you suggested here--
"However, P0401 in a 3.8 can be caused by a bad EGR valve, but a more common reason in older engines is carbon build up in the EGR passages. Carbon blocks the ports and low or no flow is the result. They can be cleaned out using a chunk of small cable and a drill. Sort of like a Roto-Rooter"
I already have purchased a new EGR valve, because the technique of soaking the original EGR for hours in cleaning solution did not work. However, the new EGR valve did not improve flow, either, and I still got the code. If there is carbon build-up in the EGR passages, maybe this procedure will clear them of exhaust soot.
So, speedometer cable length may not matter-- I plan to use the cable simply to "ream out" the EGR passages of this 3.8L v6 engine, nothing more. The "cable" I have purchased from eBay is not an actual cable, but only the wound-wire casing surrounding the cable.
Here is Scotty Kilmer's YouTube video on the technique:
https://www.youtube.com/watch?v=6_eSvvuQm1E
May 22, 2024 at 12:11 AM
ALPHAA10
  • 232 POSTS
After I have finished working with the speedometer cable, should I idle the engine or drive it around briefly before reattaching the EGR valve? I don't want loosened exhaust soot to enter the new EGR valve. Better to let it escape before reattaching the valve?
May 22, 2024 at 3:44 AM
STEVE W.
  • 15,116 POSTS
Once you have it rooted out just hit the throttle a few times to blow anything out then put it back together. If you can find a kleen screen gasket for it that would help a lot in case a chunk was still floating around.
May 22, 2024 at 8:29 AM
ALPHAA10
  • 232 POSTS
Appreciate that-- I did not know such a product existed !
Now, I can keep the EGR valve cleaner, reducing the number of derivative problems.
Just a few minutes ago, I ordered a Kleen Screen, as you recommended.
As an experiment, I might also plug in the old valve, after all the "upstream" rooting is completed, and find the old valve no longer generates a P0401 code (because a soot blockage had remained upstream, even after cleaning the old EGR valve).
May 22, 2024 at 9:14 PM
STEVE W.
  • 15,116 POSTS
See how much comes out but I've seen large chunks a few times. The 4.3 engines were really bad for carbon build up causing the EGR to stick open. Then GM decided to share the misery with other engines..
May 22, 2024 at 10:06 PM
ALPHAA10
  • 232 POSTS
Steve, after getting a few notifications from resellers that the Kleen Screen (product number 47007) is not compatible with the Buick 98 LeSabre 3.8L, I called Dorman, and spoke to a senior technician named Peter, who said Dorman does not make a Kleen Screen for the Buick.
At that, I asked Peter what he would recommend, but he had no recommendations.
Good idea, though, and thanks!
May 23, 2024 at 12:47 PM
STEVE W.
  • 15,116 POSTS
Yeah, there were a number of different companies that made them, there are also screens that just pushed into the port like a freeze plug. They have sort of gone away because of design changes that deal with carbon better. These days just finding the correct parts can cost you hair! Finding a part that was only made for a specific use can be a real headache.
BUT if you look at the Standard Products VG214 you might be surprised, and if you look at the two in the image, I attached above you might also notice something, IE just because they say it "isn't right" doesn't mean it doesn't fit. GM only used a few EGR base designs.
You might like https://www.3800pro.com/ if you want some "light" reading..
May 23, 2024 at 1:00 PM
ALPHAA10
  • 232 POSTS
Steve, one of the gaskets has exactly the right footprint for the original, so I'll call Standard Products now, and ask about their #VG214. And if they claim incompatibility, I'll ask why it will not work.
Thanks for the link to the 3800 forum-- these are very useful, which is why you use them.
Will keep you posted.
May 23, 2024 at 1:11 PM
STEVE W.
  • 15,116 POSTS
Well, considering it is in their catalog and can be bought for the 3.8 in multiple parts stores. I don't know what they will say unless they stopped making them. But the Dorman one is the same base design.
May 23, 2024 at 1:24 PM
ALPHAA10
  • 232 POSTS
Standard's technician said product VG214 will work with the pneumatic EGR valves, but not the electronic EGR valves. According to the tech representative, the wire screen "screws up the electronics".
May 23, 2024 at 1:25 PM
