Ignition will not turn off
1998 FORD TAURUS
239,705 MILES • V6 • 2WD • AUTOMATIC
BLUSTOCKSTILL
Ignition will not turn off. My key will come out but the ignition will not turn on. I have to pull a fuse to turn it off. I also have to start it by touching the cell. annoyed together. how can you help?
Aug 28, 2017 at 8:19 AM
STEVE W.
  • 15,116 POSTS
Sounds like a failed ignition switch. Easy to change out. Disconnect the battery ground connection. Drop the lower instrument panel cover. Turn the key to run.
Disconnect the electrical connector and remove the two screws that hold the switch to the steering column. Pull the switch off.
Reverse the process to install the new one. Make sure the key is in run and the new switch is in run.
Aug 28, 2017 at 8:54 AM
BLUSTOCKSTILL
How will I know if the ignition switch is in the on position?
Aug 28, 2017 at 9:59 AM
STEVE W.
  • 15,116 POSTS
The run position is the position the key comes back to after turning it to the start position.
Aug 28, 2017 at 3:38 PM
