intermitent misfire after timing belt change
1998 TOYOTA RAV4
160,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
MATS123
my timing belt broke and was replaced with a Dayco belt but now the engine is misfiring and have a rough idle. the engine type is 3s-fe. i am wondering if this is due to my battery since they tested the timing with battery disconnected. please assist.
Jul 28, 2015 at 3:17 AM
MHPAUTOS
  • 31,937 POSTS
Best get a comp test done to rule out a bent valve. and make sure that the vale timing is correct.
Jul 28, 2015 at 5:33 AM
MATS123
thank you. i will do a comp test and update.
Jul 28, 2015 at 6:22 AM
MHPAUTOS
  • 31,937 POSTS
I was getting mixed info on this engine regarding if it is an interference type engine or not, if it is you may have a bent valve, so the comp test will prove that one way or the other.
Jul 28, 2015 at 2:44 PM
