1991 Isuzu Rodeo Question Removal of water pump
1991 ISUZU RODEO
DANYALE_RAE
1991 Isuzu Rodeo Question 6 cyl Four Wheel Drive Manual
I'm working on replacing the water pump on a friends Isuzu rodeo. And I'm having problems. Manual said it should just slide out. But I'm unable to remove this darn thing. It was sealed with with silicone.
Can you help?
Thanks for you time.
Danyale Rae
Nov 3, 2010 at 9:13 PM
BLUELIGHTNIN6
  • 16,542 POSTS
are you certain everything was removed that needs to be removed? would you like replacement steps? if it had sealant in between you will have to peck it lose with a rubber mallet
Jan 3, 2020 at 4:30 PM
DANYALE_RAE
I removed all of the seal that I could get to. And whacked it a couple of times with the mallet. And it finally came lose. The gasket was completely melted.
Thanks again for your help =)
Danyale Rae
