radiator cooling fan relay location
2004 JEEP CHEROKEE
JENVDATSME
Engine Cooling problem 6 cyl Two Wheel Drive Automatic 107000 miles
Hello, can you PLEASE help me. I need to replace my relay for my radiator fan and I can not find it. I have printed out a location of where the module should be. I removed the front passenger headlight along with the bumper. and the relay module is not there. I have a 2004 jeep grand cherokee 2wd 6 cylinder. Can you please let me know if this can be any where else?? Help
May 18, 2010 at 4:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Both low and high speed radiator fan relays are in the power distribution center at right front corner of engine compartment next to the battery.
Here is a guide to help you test them
Cheers
May 18, 2010 at 10:59 PM
JENVDATSME
Thanks for the help I followed the guides and found the low speed relay was out. Once I replaced it the fans started working again.
May 19, 2010 at 10:09 PM
WLS3145
i would like to get a wire diagram of radiator fan system,
also unable to locate physical location of components such as radiator fan relay
Apr 16, 2018 at 12:49 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
The fan relays are in the PDC under the hood check the post above.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2631.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_856.jpg
