1998 Jeep Grand Cherokee ABS Light
1998 JEEP GRAND CHEROKEE
ASH2DREW
Brakes problem
1998 Jeep Grand Cherokee 6 cyl Four Wheel Drive Automatic
What is the problem when the ABS light comes on. Light comes on from time to time will stay on until turn car off and then repeats that procedure on re start
Sep 26, 2010 at 7:32 PM
BMRFIXIT
  • 19,053 POSTS
ABS light on due to a fault in the system and codes is set and need to have it scanned for codes
most common to be is a faulty sensor codes should indicate to a troubled area
Diagnostic Trouble Codes (DTCs) are stored in Controller Anti-Lock Brake (CAB) memory. DTCs are cleared using scan tool or automatically cleared after 255 ignition on-off cycles. CAB will retain DTCs with ignition off or if battery is disconnected. CAB can store more than one DTC at a time and will display number of ignition cycles since most recent DTC was stored.
DTCs detected by CAB can be latching or non-latching. Latched DTCs will disable ABS function until ignition is cycled. Non-latching DTCs occur when system fault is actually occurring causing warning light(s) to light. Warning light(s) is turned off when system fault goes away; however, in most cases a DTC will set.
Sep 26, 2010 at 8:00 PM
