key fob not working after disconnecting the battery?
2014 SUBARU FORESTER
192,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
JOHNSK62
After disconnecting the battery my key fob is not working, and my tire light is on.
Jun 15, 2025 at 6:55 AM
So what sometimes happens is the connection at the battery can cause a voltage surge which can distract the protocol for the CAN bus system. I would do a hard system reboot to restart the systems from scratch. This guide can show you how:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
Jun 16, 2025 at 10:27 AM
JOHNSK62
Hi Ken L.I tried all 3 methods and nothing. I have a 2014 Subaru Forester 2.5l .Thanks...
Jun 16, 2025 at 6:54 PM
Okay, lets check the fuse #4 and #15 in the fuse panel. Here is a guide to help you and the fuse locations in the image below.
Jun 17, 2025 at 6:46 AM
JOHNSK62
Both fuses are good...
Jun 18, 2025 at 6:13 PM
Okay, then it looks like the TPMS and keyless entry control module is out, here is the location so you can check it out. A CAN scan should help confirm it. It looks like it will need to be programmed in. Check out the images (below). Please let us know what happens.
Jun 19, 2025 at 9:43 AM
