Keyless Entry fob quit working?
2005 CHEVROLET IMPALA
120,000 MILES • 3.8L • 6 CYL • 2WD • AUTOMATIC
TBOAT13
  • 12 POSTS
My key fob quit working. I bought 2 new ones and tried to program them without success. Batteries are good. I am now thinking it might be a bad receiver. Am I on the right track, and if so, can you tell me where it is located?
Dec 12, 2025 at 6:36 AM
STEVE W.
  • 15,116 POSTS
Could you tell me the method you used to program the new remotes into the system? I normally use a scan tool to program them as I know that works. There are a few methods out there that only work on specific versions of the vehicles software.
That said the RKE receiver is under the upper dash trim panel in the middle of the vehicle. However I would use a scan tool first as it can test the module to see if it is operational and you would need the scan tool to get the replacement module to operate as it needs to be programmed into the PCM. You could also drop into any automotive locksmith and have them test your fob to see if it is or isn't operating. Did you try the resync mode? For that stand next to the car and hold the lock and unlock buttons down for 7-10 seconds the horn should beep if successful.
Dec 12, 2025 at 12:53 PM
TBOAT13
  • 12 POSTS
I followed this step x step online. I tried with old fob and 2 new ones. I decided that receiver might be bad, since I had same result with all three.
Dec 12, 2025 at 3:16 PM
STEVE W.
  • 15,116 POSTS
I would have a scan tool try before condemning the receiver. As I said there are times that the vehicle may have slightly different software or options and things don't work. Much easier to verify it that way than to take the dash apart, source a module and have it installed to discover it doesn't make a difference. Where did you get the new fobs and are they OEM or?? Asking because you cannot program used ones in on most GM vehicles and with the aftermarket all bets are off in terms of parts working these days. I've had brand new parts like alternators and ignition coils that were bad when they came out of the box!
Dec 12, 2025 at 4:01 PM
TBOAT13
  • 12 POSTS
I haven't done the scan tool option yet, but yesterday morning I went to car and original fob worked. I then retried programming on fobs I bought from Amazon and it worked. I then had 3 working fobs. But, later in the day, none of them would work. I don't know how much a shop would charge for scan, but I will check on it next week. Thanks.
Dec 14, 2025 at 7:48 AM
STEVE W.
  • 15,116 POSTS
OK, so the fobs started working but then all three failed? That should mean that they are good at least. You changed nothing? IE didn't carry a different cell phone or start charging one and were not near anything like a radio tower? Was there any temperature changes between the times they did/didn't work? Heater on AC on? Asking because if something like that changed the system it would point somewhat to a communication issue or possibly cracked solder joints that are temperature sensitive in the receiver.
Changing it out requires that the two side trim panels for the windshield be removed, then the trim around the instrument panel, then you GENTLY pry up the defrost grid. Then remove all of the screws that hold the upper pad in place. Flip it up and under it you will find the RKE receiver clipped in place. I might try unplugging the connector and checking for corrosion and maybe reseating the connector a few times if the connection looks dirty. If it looks OK, then replace the receiver. Then you need to program in the remotes again.
Dec 14, 2025 at 10:37 AM
TBOAT13
  • 12 POSTS
I replaced receiver and all working fine for now. One thing that had me going in circles, though. I didn't realize that, if you don't program all in same session, only the last one will work. Previously programmed remotes are not recognized by receiver. Thanks for your help.
Dec 15, 2025 at 1:00 PM
STEVE W.
  • 15,116 POSTS
Good to hear that it's working. Yes, the fobs all need to be programmed in the same session. That is because entering programming erases the stored fobs. It's actually a good thing, say you are out somewhere and lose the fob you have, you can enter programming mode and delete that fob so it becomes unusable.
Dec 15, 2025 at 1:56 PM
